Need Advice on buying 37" Plasma/LCD
Discussion in 'Plasma TVs Forum' started by skoobidude, Aug 14, 2005.
  1. skoobidude
    skoobidude
    Aug 14, 2005
    11
    I've been looking at buying a flatscreen for the past month now and have decided I would like to make a purchase. I would be grateful if you could help me with my selection:-
    1. It has to be 37" as any bigger would "take over the room".
    2. It has to have a dark/black frame - the slimmer the better.
    3. I'm leaning towards having a monitor rather than built in TV tuner as I'm having Sky+ installed and planning on Surround Speaker system
    4. I don't want a huge glass stand as I personally do not like to see the cables hanging out the rear etc so only a table top stand will do. NB It is my understanding that most makes can be adapted for either type of mounting.
    Models that have caught my attention in local electrical stores are:
    Hitatchi
    Panasonic
    LG
    Pioneer (although the smallest I've seen is 42")
    What do you people think? I know most of you are going to mention HD readiness so I will consider this also.
    thanks
    Nick
  2. skoobidude
    skoobidude
    Aug 14, 2005
    11
    Oh, no replies! BOOOO HOOO....
    pleaase!
  3. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    How much are you looking to spend ? This would help people suggest models within your budget then.
  4. skoobidude
    skoobidude
    Aug 14, 2005
    11
    Looking at spending up to £2k.
    Also, am I right in saying that I'd be better off buying from internet rather than local electrical retailers?
    Nick
  5. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Take a look at the JVC LT-37DS6.
    There are threads on here about it and longer threads about its smaller relations, the LT-26DS6 & LT-32DS6. All are similar.
    You will usually get a better price off the Internet but if you value decent service, try to find a local dealer with whatever you finally choose in stock.
