Need Advice on Bravia TV
Discussion in 'LCD & LED LCD TVs Forum' started by Panky79, Jan 20, 2008.
Tags:
  1. Panky79
    Panky79
    Im looking at buying the:
    "Sony KDL32S3000 - 32'' Widescreen Bravia HD Ready LCD TV - With Freeview"
    And i need advice on the picture quality with a Playstation 2 console. Because its not through HD like a PS3 would, would this make the picture blur/ghost at all? If it does, would it effect the game much if i where to play Fifa 08?
    Ive heard the picture and sound are outstanding for this television in the normal analog and freview settings with the Tv. But i also want to use it for gaming. Any advice?
  2. DANRB
    DANRB
    Dec 28, 2006
    615
    +19
    I have a 40W2000 that I use a PS2 with. Purchased a component out cable from ebay for it for £6 and its fine. Much better picture than the standard component cable!! No ghosting at all.
  3. Panky79
    Panky79
    Hey, thanks for the advice, i know nothing about cables, what do i need to look for and how would i use this cable with my PS2 and TV?
