Need advice on a proposed ITX build
Discussion in 'Desktop & Laptop Computers Forum' started by t-1000, Nov 29, 2010.
  1. t-1000
    t-1000
    Dec 21, 2005
    63
    Ive decided to replace my aged cube comp with something a little smaller. Anyway my basic idea spec wise is as follows
    Case Thermaltake Element Q
    Zotac H55 - ITX motherboard
    Intel core i3 540
    4 Gb DDR3 1333 memory
    Possibly 60gb SSD drive for windows installation
    Cd drive and another sata HD from my current computer
    The comp will mainly be used for browsing, watching bbc iplayer, HD youtube, and general email/word. Thats about it.
    Anyway anyone have any ideas if the above will be a decent start and if Ive missed anything?
    Rich
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,473
    2
    +1,366
  3. tappet
    tappet
    Nov 29, 2010
    24
    3
    +4
    I just built one using Gigabyte GA-H55N-USB3, found it to be a good board.:)
  4. t-1000
    t-1000
    Dec 21, 2005
    63
    Looks good. I like the idea of built in wifi though. What cpu/case did you use? Also ate you using on board graphics?
  5. bladedripper
    bladedripper
    Nov 26, 2007
    5,072
    Birmingham
    +1,527
    Got one fo these coming with a sugo sg07 case and gtx 580.:D
  6. tappet
    tappet
    Nov 29, 2010
    24
    3
    +4
    TBH had a shuttle case that the MoBo went, so modified the case to take the ITX, and the CPU was a i3 530. Onboard GPU works OK for general apps and works the cpu @ 6% with 1080p Bluray or MKV'S.:)
  7. tappet
    tappet
    Nov 29, 2010
    24
    3
    +4
    Liking the case:D:D, the graphics card looks bigger than the MoBo:laugh:
  8. bladedripper
    bladedripper
    Nov 26, 2007
    5,072
    Birmingham
    +1,527
    All done at cyberpower,infinity game cube.:D
  9. the_beast
    the_beast
    Jan 9, 2008
    170
    28
    +26
    How is your budget? If it's tight, then you can do all that with a simple Atom build, which will save a bunch of cash.
    However I would still go for a mATX build rather than a mITX build - lower cost, but more expandability, and very little size difference at the end of the day.
  10. t-1000
    t-1000
    Dec 21, 2005
    63
    Yeah I've decided to upgrade my existing maxt cube as its not much bigger than an itx and about half the cost.
    Thanks for all the advice anyway guys
