Need Advice (newbie)
Discussion in 'Home Cinema Building DIY' started by louishm, Jun 13, 2005.
  1. louishm
    louishm
    Jun 6, 2005
    2,006
    Manchester
    +57
    HI ALL..
    I HAVE JUST PURCHASED A NEW HOUSE WHICH HAS A LARGE CELLAR ROOM WHICH I WANT TO TURN INTO A HOME THEATRE AND I HAVE ALREADY BEEN GETTING THE STUFF TOGETHER BUT WANTED TO MAKE SURE I HAD EVERYTHING..
    1: EPSON EMP-TW10
    2: Panasonic Sc-dt110 Home Cinema 5.1 Dvd Player
    3: Sony SFCR500H (5 speaker package)
    5: 6 IN 1 OUT VIDEO SELECTOR (MAPLINS)
    6: XBOX
    7: PS2
    8: VCR (JUST FOR THE TUNER)
    AS YOU CAN SEE MY FINANCES AT THE MOMENT ARE LIMITED AS THE HOUSE AND THE BUILD OF THE ROOM WILL EXHAUST MY WALLET.
    I AM GOING TO USE THE DVD PLAYERS AMP FOR MY SOUND AND I WILL PROBABLY GET AN AV RECIEVER IN THE FUTURE
    BUT I JUST WANTED TO CHECK TO SEE IF I HAD EVERYTHING IN PLACE TO START THIS PROJECT
    THANKS
  2. inzaman
    inzaman
    Dec 16, 2002
    7,963
    Derby
    +1,026
    You seem to have all bases covered, does the above also include amplification. Also are you having the cellar tanked etc or is it a dry room.
  3. louishm
    louishm
    Jun 6, 2005
    2,006
    Manchester
    +57
    we have just had the survey done and paid extra to have a proper damp check done on the cellar and it came back "no damp" and the surveyer said the rooms were suprisingly dry.
    my dvd player is a panasonic 5.1 with two extra av inputs so for now i will use these to produce sound for my other inputs, i am using this at the moment on my normal tv and it works fine with my xbox and ps2
    thanks
    paul
