need advice .. for new aerial and set up
Discussion in 'Freeview & YouView' started by DT.SMOKIN, Jan 13, 2008.
  1. DT.SMOKIN
    DT.SMOKIN
    Dec 22, 2007
    88
    +4
    hi all . right i need a few pointers from you guys .. on which aerial i should buy and supporting products ...to recieve freeview in my house .. + i will be looking to distrubute the signal to 4 rooms .. 3 bedrooms + living room
    so tell me what i need and products you reccomend for this set-up
    hopefully screw-fix has all i need.. so u can post the links till what i need :thumbsup:
    my postcde is BT422QE
    thnx ryan
  2. gulliver dark
    gulliver dark
    Jan 6, 2008
    146
    Eastbourne
    +10
    Regarding the aerial - impossible to say for certain what you need without seeing your house - you might be quite near a transmitter but there might be a block of flats in the way - but for a DIY job; you're saving on paying a firm so take advantage of that to get the best aerial you can afford. I would say, as a fellow DIYer, work out what aerial you need based on how well your house is placed is positioned in relation to the trasmitter and what aerials your neighbours have - then get the next aerial bigger.
    Regarding aerials - obviously you don't want to pay an excessive amount but some people, and I'm not saying you, set out to find the cheapest aerial. I would say get the best aerial you can afford - one of the good makes.
  3. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
  4. mike10u
    mike10u
    Jan 14, 2008
    16
    Very useful info. According to wolfbane I need high gain aerial,which i already have(dab45), but still have some noise interference/occasional freezing on some channels. My aerial is in the loft ,booster is a 4 way maxview 13db,and humax freeview signals range from 20--60% at best. What else can I use to boost signal ? a mast head amp? anyone please[​IMG]
  5. JayCee
    JayCee
    Jan 20, 2004
    23,628
    Lanarkshire
    +2,550
    The greatest improvement you could make is to get your aerial outside the loft...you may then not need a masthead amp.
