PlaTyPuS
Hi!
Before I ask my question, here is my current setup:
I would like to bring the sound which is played in my living room to my kitchen. When I'm cooking and still want to listen to the music or follow a soccer game, I currently need to increase the volume in my living room so I can hear something from my kitchen.... far from ideal :-(.
I'm also planning to change the speakers I have in my living room by some other ones, so I could maybe use 2 of the current one (Teufel motiv) in the kitchen, but as they're not wireless there's maybe a simpler solution.
What would be the best solution? The AVR I have don't have HEOS built-in, and what I understood of those streaming solution (airplay2, heos, bluesound) is that it would not work if I'm watching a soccer game right (as I'm watching those from a shield pro, as almost all other content btw)?
So at the end I'm not sure about the solution I have to be able to play a sound from my shield to my living room & kitchen at the same time (sound should be perfectly in sync!!! very important!). Distance between my living room & kitchen (cable wise) would be something like ~30m.
Thanks for your advices.
- Denon x3300
- Teufel Motiv 3 (5.1 system)
- 2 Polk Audio atmos speakers
