Need a Wall Bracket for my Samsung LE40M86
  • Thread starter Deleted member 92943
  • Start date
D
Hey guys
I'm expecting delivery of a Samsung LE40M86 (40'') in the next 10 days or so and in the meantime i need to buy a new wall bracket.
I'm looking for an all signing all dancing one with Dual arm movement, Tilt, Swivel and rotate.
I didn't want to pay more than £150 but i have seen these 2 to start
Model 44 and costs £180
http://cpc.farnell.com/jsp/level5/module.jsp?moduleId=cpc/471188.xml
And this one at Amazon
http://www.amazon.co.uk/Samsung-LE40M87BDX-Bracket-Cantilever-Extension/dp/B000QYL7UW/ref=pd_bbs_sr_10?ie=UTF8&s=electronics&qid=1199920255&sr=8-10
Perhaps one in between those two at £120 and does the same as the £180 one?
Any advice and help is appricated:thumbsup:
KUBBY
Try VIVOMOUNTS,good selection and prices.
KH
D
sorry.
Can someone just confirm for me that the bracket in ym last post (around £180) will be fine for the Samsung 40'' LCD as i want to order it before the TV is shipped to me
Curly99
As long as it is the correct vesa size and the weight is ok the bracket should be ok, what would worry me though is the way it fits to the wall the bracket seems to have a small foot print but saying that if it's going on to a good wall with say ancour bolts you should be ok.
Curly
D
It's the footprint that worries me too. The wall it's going on is bloody strong and take aages to dril thorugh
Curly99
I would have thought as long as you install it correctly as per the instructions you should be ok.
Curly
The BEST TV of 2023? LG G3 MLA OLED Evo TV Review - COMPARED to Samsung S95C & QN95C
Back
