Need a TV that will do ntsc 3.58, 4.58 and PAL
Discussion in 'General TV Discussions Forum' started by p4ntb0y, Nov 23, 2003.
  1. p4ntb0y
    p4ntb0y
    I have lots of Japanese Stuff like a
    Japanese Camrecorder,
    Japanese Game Q (Its made by matu****a has a DVD player in it).
    I am in the UK.
    I would like to know what TVS 21" ish will best suit my needs.
    I would like to have a flat screen.
    I have about 300 pounds for this item.
    So if anyone can reccomend me a TV I would be gratfull.
  2. Loada
    Loada
    Mar 4, 2003
    592
    Guisborough, North Yorkshire
    +51
    I have a 21" Sony flatscreen Wega (LS21?) that does the job admirably. I bought it (about a year ago) for around £280 predominantly as a gaming TV to run import games consoles on. I've tested it with the following and had no problems whatsoever:
    USA Xbox (NTSC 3.58) via SVIDEO/Comp
    UK Xbox (PAL60/NTSC 4.43 and PAL50) via SVIDEO/Comp
    USA/JAP Gamecubes (NTSC 3.58) via SVIDEO
    USA Dreamcast (NTSC 3.58) via SVIDEO
    USA/JAP Super Nintendo (NTSC 3.58) via RGB-SCART/SVideo
    UK PS1 (NTSC 3.58 and PAL) via RGB-SCART
    USA N64 (NTSC 3.58) via SVIDEO/Comp
    The TV has 2 SCARTS, one is RGB-capable, and it has composite socketry under the front flap. It is 4:3 aspect (not widescreen) but that's not really an issue for me.
    I've had older Sony 21" in the past for the same task and I didn't hesitate when I had to buy a new one. They are more expensive than the competition but they work flawlessly with NTSC without any screen-shifting or aspect problems. I've had some terrible (read: cheaper) 21" TVs which have mucked around with the picture in NTSC mode (offsetting and the like) and I found you definitely get what you pay for.
    Another set to look out for might be one by Toshiba, as they too understand the importance of a decent NTSC picture. However, I don't have any direct experience of them to confirm that so you might have to try before you buy.
    Hope that helps!
  3. p4ntb0y
    p4ntb0y
    Many Thanks this sounds like exactly what I need!!
