need a serial/ RS232/ 9 pn din to SCART cable?
Discussion in 'Cables & Switches' started by roversd1, Jun 22, 2005.
  1. roversd1
    roversd1
    Can anyone assist?
    it needs to be good quality as its for a freeveiw box to plasma.
    Call me thick if they are available everywhere, I couldnt find one...
    Ta...
  2. roversd1
    roversd1
    bump...
  3. Peridot
    Peridot
    Aug 24, 2004
    2,977
    Newport, South Wales
    +293
    Do you mean SCART to 15-pin VGA input on the Plasma?
    Is it for video display? AFAIK you can't connect directly but need something like the JS or Keane converter.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,548
    The Borders
    +3,024
    roversd1
    As Peridot points out you have a VERY odd Display if it can Input a Video signal on its 9-Pin D-Type connector - the RS232 port is used for controlling the Display from an external device its not a Video Input.
    You may also have a 15-Pin D-Type 'VGA' connector on the Display and if your Display can accept Video as well as PC signals on the HD15 socket you may be able to Input a signal from a Digibox or similar.
    Which Display do you have?
    Best regards
    Joe
  5. roversd1
    roversd1
    'eeeeeeeeet!'
    The freeveiw box has a serial port instead of a scart socket. The cable is lousy with a very bad earth connectiong.
    Maybe I should have been clearer, so apologies for that.
    The irony is that the freeveiw box in question (Happauge 1100DEC) fried itself anyway!
