kirkbaueratl
I used to be pretty happy with my Roku devices, but now I'm looking for something else. First some background.
I had a Roku 4 with an old HD TV and was perfectly happy. Then I bought a 2017 LG OLED 65" CX and the Roku didn't support HDR, but that was OK because I could do Netflix, Amazon, and Hulu directly on the LG TV. Then we wanted to watch some Apple TV so I needed to upgrade to a newer Roku, so I got the Roku Ultra that was released in November 2020. It theoretically supported both HDR and Dolby Atmos (which is what I have for audio).
That is when things get crazy. If I connected the Roku through my Denon AVR-X6300H I had Dolby Atmos, but even though it would auto-detect 4K HDR it didn't actually work when it switched to it. If I connected it directly to my TV then 4K HDR would work but my TV can't pass Atmos through to the receiver. Then after some time, neither configuration would work properly, so I returned the Roku and re-connected my old Roku 4. At the same time, my wife wanted a bigger TV in the bedroom so I move my OLED 65" to the bedroom and bought a 2020 LG OLED 77" CX. Funny enough that TV can now run AppleTV natively, but it doesn't support HBO Max (at least right now) so I'm using my old Roku 4 for HBO Max and that's it.
But then I found out that the latest LG OLEDs don't support DTS audio tracks. Well, that's a problem because for all of my non-4K Blu-ray discs I have them on a NAS for convenient access around the house, and many of them have DTS audio tracks. So my LG TV can do everything except (1) HBO Max and (2) play some DTS, 2K MKV files from the network.
I have tried Plex in the past but have had no success due to poor performance. All of my MKV files are full original resolution, so for some Blu-ray discs they are up to 50GB or so. If I install the Plex app on my old Synology NAS it can't keep up.
So what I'm looking for ideally is a device that supports 4K HDR and Atmos that also supports HBO Max and can play MKV files with DTS audio. Is there such a thing?
Alternatively, I can stick with the Roku 4 until hopefully HBO Max becomes available on my LG TV. In that case I just need something to play MKV files.
Any suggestions?
Any suggestions?
