Quantcast
Need a replacement lamp for my Panasonic PT-AE900E
Glenn Keen
The lamp has failed in my Panasonic PT-AE900E and I'm looking for a replacement.
Whilst I know the projector is old, it won't be getting replaced for another year so in the mean time I need a lamp.
I can't seam to find an original bulb and housing but I am finding a lot of "original lamp inside" ones.
Does anyone have experience with these, and if so do you have any companies that you would recommend.
Many thanks for any info/advice.
