Need a Nice Integrated Amp -- Help!
Discussion in 'AV Receivers & Amplifiers' started by Allen Meyerhoff, Dec 3, 2004.
  1. Allen Meyerhoff
    Allen Meyerhoff
    I've just purchased a pair of B&W Nautilus 802s, and want a new integrated amp to go with them. The room is about 400 square feet, mostly hardwood floors, average amount of furniture, and has two 2 meter openings to other rooms. Looking to spend $800 - $1300.
    Any suggestions?
  2. Dfour
    Dfour
    Jan 19, 2004
    4,021
    71
    Bracknell
    +86
    The only problem with helping you is this is mainly a UK site so the models and prices can be different over here to where you are.
    What is going to be the main use of the amp? Music or movies?
  3. Allen Meyerhoff
    Allen Meyerhoff
    Thanks so much for your help. 95% of use is music ... blues, classical, some pop, jazz ... far more acoustic than electric music.
    The 802s are Nautilus, and sell for approx. 3500 pounds.
  4. Allen Meyerhoff
    Allen Meyerhoff
    Dfour, if you read this, the model number in the UK is same as US ... 802.
  5. davee
    davee
    Jun 15, 2004
    706
    twickenham
    +57
    Personally I'd be looking to spend more than $1000 on an av receiver to partner the B&Ws. Given that you're in the states you're going to get better value for money (unfortunately) by buying US kit. $1.94 to the £ = Good for uk buyers bad for uk exporters!
  6. Dfour
    Dfour
    Jan 19, 2004
    4,021
    71
    Bracknell
    +86
    So something like the Arcam 300 or hte 250 would be good or an intergrated/pre+power combo rotel even.
  7. Knightshade
    Knightshade
    Aug 6, 2004
    1,996
    +43
    Would suggest something by Chord or Krell for that class speaker but you may struggle on your budget.
  8. Allen Meyerhoff
    Allen Meyerhoff
    Although I got an excellent price on the 802s, I want to do them justice. If that means spending up to L1000, I'll do it.
  9. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    I agree, a cheap amp will make the speakers sound dreadful. Most high end amps such as Krell etc will work well. A £1000 AV amp, I suspect will not do the B&W's justice
  10. Allen Meyerhoff
    Allen Meyerhoff
    Thanks so much. I hear the (fiscal) music ... thanks to you all ... I'll happily spend WHATEVER is reasonable to do the 802s justice, including >L1000.
    Suggestions?
