Need a new TV. 42" - 47". Budget £800
Discussion in 'What Is The Best TV For You?' started by sjackson, Sep 9, 2012.
  1. sjackson
    sjackson
    Jan 8, 2006
    2,187
    116
    Ireland
    +538
    Hi All,
    As with most on this sub-forum, I seem to feel overwhelmed with the choices on offer. Hopefully if I set out my needs, someone can recommend a TV....
    Budget: up to £800
    Size: Between 42" and 47"
    Use: Standard Definition TV (don't have Sky HD), Sports, HD movies, iPlayer, 4od.
    No gaming and not particularly bothered with 3D.
    Wishlist: Smart functions & an Ethernet port so I can play content from the network, full HD (1080p).
    LED/LCD or Plasma doesn't bother me. I want the best picture for the money. The room itself is around 14" square but not overly bright most of the time. The TV will be located in a corner beside a window.
    Any advice would be appreciated!
