Need a new machine to read my -R discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by dude1971, Nov 3, 2003.
  1. dude1971
    dude1971
    My current machine, LG3200, is playing up (won't read some -R discs that I've tested in other machines, freezes on some discs (The Hours, Spiderman) so I've decided to trade it in as I have the extended gurantee from Richer Sounds.
    Can anyone recommend a decent player under £100 that will handle -R and VCD's (multi-region, naturally). I've got no preference, but would probably avoid Toshiba as I've got one of their videos and it's given me loads of problems.
    Please don't suggest a Panasonic DVD recorder as I'm buying one of those anyway next week :)
    Thanx
    Dude
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
  4. dude1971
    dude1971
    Hi Rasczak. Been reading lots of your posts, it's thanks to you that I'll be buying an E60 so thank you for the advice.
    I edited my post, as I meant £100, sorry :-(
    I wasn't aware that you could get a DVD player that would play RAM for under £100 so I'll check them out.
    Thanks again for all your posts in these forums. I've heard that you are off to Japan? Good luck with future ventures mate.
    Regards
    Dude
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    The reviews for the two players are online on the What Video (and whatever they are calling themselves this month) site.
    The S35 review is here:
    http://www.whatvideotv.com/testbenc...v.com/cgi-bin/displayreview.php?reviewid=2991
    The S75 review is here:
    http://www.whatvideotv.com/testbenc...v.com/cgi-bin/displayreview.php?reviewid=2954
    Yes - for six months (or thereabouts) on work. Over Christmas as well :( But I will be back :D
  6. dude1971
    dude1971
    Blimey, I thought it was only me that got up this early :-0
    Thanks for saving me the time to hunt down those reviews, I can get on with some work :)
    Regards
    Dude
    p.s. By the time you return, you can convince us all to get Blu Ray!
  7. dude1971
    dude1971
    Will both these machines take caddied DVD-Ram discs?
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Afraid not. You can't get a UK standalone DVD player that will play caddied DVD-RAMs :( You can take caddied media out of it's caddy though (at least Type II media anyway)
  9. dude1971
    dude1971
    But isn't the point of the caddy to protect them? And Type II is 'formulated for specialist commercial applications' according to www.cd-r media.co.uk so I was looking at Type I for 'more general use'. But if Type II is the one that can be opened then so be it.
    As if it wasn't confusing enough...
    The S75 is £115 at Richer Sounds, will be getting one at the weekend (if the missus is in a good mood...)
  10. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Yes - in an ideal world (IMHO) all media would be caddied. Panasonic, JVC and Toshiba disagree.
    No it's not. A Type II disk can just be taken out the caddy. Sometimes such disks can be 'protected' for non-caddied use (such as the Panasonic non-caddied disks) but it's not a requirement of it being a "Type 2" disk.
    We haven't even started talking about DVD-RAM Types 5 through to 9 yet! :D
  11. dude1971
    dude1971
    So, as I will be buying the E60 primarily to record my camcorder footage, I need to be sure about this. I can dump my entire camcorder footage onto a Type II DVD-Ram disk. I then play it back on a S75 and edit it on another Type II DVD-Ram disk. Once I'm happy with it, I play that disk on my S75 and finalise it to a DVD-R disk.
    Does that make sense? Do I make sense?
    And yes, I could buy an HS2 to do all that but let's not go down that road :-#
  12. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Well yes you could do it that way or you could do it in stages. One example:
    Say you have 2 hours of footage but you want to edit and only archive say 1.5 hours. The edits you want to make are equally spaced throughout the recording.
    You copy 1 hour of your camcorder footage to DVD-RAM in XP mode. You edit (using "Partial Erase") taking the recording down to 45mins. You put the disk in the S75 and set the recording mode to Flexible Record set at 1hr 30mins and copy the recording onto DVD-R. Do not finalise the disk at this stage. Remove the DVD-R from the E60.
    Now record the final 1 hour of camcorder footage onto the DVD-RAM disk in XP mode. Edit as required (again taking it down to 45 minutes). Play in the S75 with the E60 recording onto DVD-R in FR set to 45 minutes. Finalise the DVD-R.
    With regard to the DVD-RAM disks you buy - as you'll be using them with the S75 I suggest you go primarily for non-caddied disks as these have a 'protection layer' that caddied disks do not have (at least major brand ones do).
  13. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    dude1971 - I hope my post above makes some sort of sense to you. Believe me it will once you've used the E60 a bit!
  14. dude1971
    dude1971
    I've copied this into a Word document for future use, I'll let you know how I get on. I'm sure it will make sense when I do my first edit.
    Thanks again Rasczak
    Regards
    Dude
    p.s. Noticed a very similar conversation you are having on another thread, so it seems I'm not the only one thinking about doing it this way!
  15. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    No your not the only one doing this. I've had a couple of dozen people ask me how to do this.
    Just to point out the obvious I suggest when you get the machine you do a number of test recordings - play a RAM on your S75 and recording onto another RAM on your E60. This will avoid you wasting any DVD-Rs until your happy how the machine works etc.
  16. dude1971
    dude1971
    1 final question, as I'll be calling Richer Sounds when they open this morning, what cables do I use to connect the 2 machines? A quality scart or something else?
    Dude
  17. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Yes a good quality Scart will ensure you get the most out of it. QED offers a good compromise between quality and cost. The RGB Scart output on the S35/75 can then be connected to the RGB input (AV2) on the E50/60.
    Some people who go this route prefer to just connect the S35/75 to the E50/60 when copying DVD-RAMs, others prefer a permament connection. A system setup for the latter would be:
    Sky TV Out > 2Into1 Switcher > AV2 E50
    S35/75 Out > 2Into1 Switcher > AV2 E50
    This would obviously involve purchase of a 2 Into 1 Switch box from a place such as Lektropacks:
    http://www.lektropacks.co.uk/
