Need a New Graphics card, Advice Please
Discussion in 'Computer Components' started by NathRSW, Jan 11, 2008.
  1. NathRSW
    NathRSW
    Jan 11, 2008
    3
    Hi everyone, Been lurking around these forums for a good while but this is my first post.
    I recently had Call of Duty 4 brought as a christmas present for the PC, I dont really play PC games but i like Call of Duty so i want to get it working, When i try and run the game it says my graphics card does not support Direct X 9 Games
    My Specs are as follows (Well these are what i can rememeber, At work at the mo)
    - AMD Athlon 64 - 3000+ (Socket 754)
    - 3 X 512MB PC3200 DDR Memory
    What im after is a graphics card that will support Call of Duty 4 and most of the current games out at the moment but at the same time i know my PC is not top of the range so dont want to invest in a grpahics card if more powerfull that my PC
    Dont really know what im talking about. Basically I want graphics card that wont be letting my PC performance down.
    Reccomendations Plz :)
  2. Zarch
    Zarch
    Jan 23, 2003
    3,577
    Sheffield
    +833
    What slot has your motherboard got? AGP or PCI-e?
    And how much do you want to spend? Anything between £50 and £350 could be advised!! :eek:
  3. NathRSW
    NathRSW
    Jan 11, 2008
    3
    Thats my motherboard below.
    http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000053
    According to the specs it has the following
    1 x AGP 8X, 5 x PCI
    I think the graphics card I have in at the moment is AGP, I have a few PCI slots availble too
    Looking for a Graphics card that will play COD4 and other games at the mininum requriments on the lowest budget possible.
    Many thanks
  4. Zarch
    Zarch
    Jan 23, 2003
    3,577
    Sheffield
    +833
    Any of the following are Nvidia Direct X 9 and come in AGP.
    Nvidia 5200,6200,6600,6800,7600,7800,7900,7590
    Have a look on scan.co.uk, prices are between £25 and £150.
    Have a look on Toms Hardware for relative performance figures: http://www23.tomshardware.com/graphics_2006.html
  5. NathRSW
    NathRSW
    Jan 11, 2008
    3
    OK quick question
    Are there many Games out or coming out very soon that will only be playable with a DirectX10 Graphics card
    I take it you cant get a AGP DX10 Card?
  6. Zarch
    Zarch
    Jan 23, 2003
    3,577
    Sheffield
    +833
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,974
    London
    +1,148
    Yes you can, Sapphire have details regarding their HD 3850 AGP here. :)
  8. Sukh88
    Sukh88
    Jan 1, 2008
    250
    28
    London
    +25
    If you want to play DX10 games in the future i would recommend you upgrade your rig to get decent frame rates as you will need to upgrade your OS to Vista (which will reqiure 2GB RAM)
    Otherwise any AGP card that Mickwall posted will be fine for basic/decent DX9 gaming.
    Hope this helps
    Sukh
