Need a new CD Player - not sure if its worth spending quite a bit
Discussion in 'Hi-Fi Stereo Systems & Separates' started by deadmoon, May 2, 2007.
  1. deadmoon
    deadmoon
    Apr 3, 2007
    I just got new speakers & an amp, and now need a cd player.
    I am tempted to just get a cheap one (about 150 quid ish), but want to know if its worth me spending more (maybe upto about 200 quid). Is there really that much difference in them?
    Can anyone recommend some (in silver)?
    Thanks:clap:
    edit -
    I've just come across this - http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/2830/source/kelkoo - DENON DCD700AE CD PLAYER, for £200, and it says it plays MP3s and WMAs, which would be very handy, could then burn loads of mp3s to one cd and would hold a lot more than a normal audio cd. Is it any good?
  2. matt303
    matt303
    Dec 3, 2006
    151
    +19
    CD players can be quite different, if you want to hear the difference simply find a local retailer that has some players in your price range and book a demo.
  3. deadmoon
    deadmoon
    Apr 3, 2007
    Tbh, think now i'll just go after something cheap and order it online. Anyone got any reccomendations as to what is good value for money, online?
  4. harrygrey382
    harrygrey382
    you'd get some awesome value if you went second hand. £150 could get you something super like a Meridian 206, would kick anything in the new budget of £200, hell, maybe double that. Plenty others too...
  5. Jonesi
    Jonesi
    I've just bought a Marantz CD63 Mk2 KI Signature via eBay for £100 and would recommend one. I prefer the sound to that of my Cambridge Audio Azur 640C (purchased from Richer Sounds for £250 four years ago!)
    What amp and speakers do you have?
  6. deadmoon
    deadmoon
    Apr 3, 2007
    I had a quick look, and it seems that model is about 10 years old!!??? Surely newer cd players are far better quality...??
  7. matt303
    matt303
    Dec 3, 2006
    151
    +19
    A few weeks back I took my Arcam Alpha 6 CD player and Delta 90 amp around to a mates house so he could hear his Kef iQ5 speakers running with a good CD player and amp rather than the 360 and AV amp he was using. Needless to say the CD player made a big difference and the amp further improved things, so he went and spent £450 on an Arcam Diva CD73. I've asked him how he's getting on with it and he thinks my Alpha 6 has the edge over it, especially with how well it presents an almost 3D sound. So there are some used bargains to be got if you know what to look for, you can always buy try and sell on with used stuff until you settle on something.
  8. Light_User
    Light_User
    Feb 10, 2005
    305
    +6
    I thought the same and recently bought a secondhand NAD C541i cd player circa 2003 "best buy", rrp £320 etc, to replace my Rotel rcd-950, made in 1996 (£400 ish?) and on its last legs. Unfortunately, the Rotel slaughters it :eek: :thumbsdow .
    Newer is no guarantee to be better.
  9. MikeFaulkner
    MikeFaulkner
    Apr 12, 2007
    234
    Liverpool, UK
    +37
    I just picked up an Arcam Diva CD62 for £70 and it is absolutely superb, OK it didn't come with the correct remote, but what the hell. Second hand is fine provided you can get some sort of guarantee, even if it is only a couple of months.
  10. jimok78
    jimok78
    Oct 2, 2006
    36
  11. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Rega Apollo has a good rep but is a bit above your budget.
