need a new car pump
mjn
You've an inflatable car?
FZR400RRSP
Carry it around with you?
In the car, or do you walk around rescuing deflated tyres?
Pumperman!!!
FWIW, I have a twin-barrel Michelin footpump in the boot.
Prefer it to those awful electric pumps with wires and BRRRRRRRR noise.
There is a squeak when I use it though.
Unsure if it's the pump or me.
car-man
Pumperman!!!
I think you will find the squeak is coming from the rods that go into the pump barrels....a dab of grease on the shafts should fix it.
Hem
Personally I would steer clear of the Michelin twin barrel foot pump, I have one at it is an extremely poorly constructed product which is only around 18 months old and already about to be consigned to the bin. Check Amazon for an array of negative reviews on this item.
FZR400RRSP
Must have changed factories or something then, mine is years old.
Gets weekly use by me and often borrowed by colleagues too bloody lazy to buy their own....
un1eash
Dont bother with electric ones, ive had 3 now and they all broke after very little use. I stick with my cheap £5 foot pump now.
skhan786
Foot pump take too long to pump up theh tyres
And yes electric pumps break quick well the ones I got anyways thatss why I'm asking here if anyone has used a pump and they happy with it please do let me know
lovegroova
Michelin Twin Barrel here too.
My newer one seems to be much worse quality than my older one.
FZR400RRSP
Del45 said:
A tip for you here, bicycle pumps work on a car, I have one of these...
Bontrager Charger Pump | Evans Cycles
And it's better than any foot pump I have owned.
The only problem with this is volume.
Although a bike tyre runs higher psi than a car, there's nowhere near the same volume of air.
So a bike pump doesn't have to 'move' as much air to increase psi in a bike tyre.
Subsequently, you could find yourself having to put a lot of effort in to get even 1psi difference in your car tyre.
And if you're looking at more than a few psi, you could be there for ages.
So, yes, a bike pump will work, but it's a bit like using a syringe to refuel your car.
bearman3784
FZR400RRSP
shahedz said:
I just go BP 20p and a lot quicker and less hassel
If you're relying on the garage airline pressure gauge, good luck with that.
Notoriously inaccurate.
If you're merely using their line and checking the pressure yourself, fair enough.
I do pressures weekly on two cars.
So that would be 40p a week = £20 a year.
FZR400RRSP
I read an IAM study report that said even the digital ones they measured were between 5% and 8% out at 30 psi.
Not good enough for me.
I get my digital gauge checked every now and then by a calibration company we use for our scales and other measuring equipment at work.
Sounds like I'm anal about tyre pressures, which isn't the case.
I'm just one of those drivers that can 'feel' a drop in pressure of only a few psi in any of my tyres.
Going by the visibly soft tyres you see around, many drivers only care once their wheels start rubbing the road.....
jenam93
Another vote for the Michelin twin barrel from me. For checking Tyre pressures and minor inflations I would say you would almost have all finished by the time you unpack a digital one and get the cables sorted.
