Need a freeview box today - cheap!
Discussion in 'Freeview & YouView' started by Unlight, Oct 11, 2004.
  1. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Hey there,
    Whats the best "cheap" freeview box that I can purchase on the high street/major chains?
    I need a TV signal for my Panasonic PW6, just need something basic so I can get TV channels on.
    A Scart socket that outputs RGB is a must!
    Anyone?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Richersounds your best bet mate cheap and nasty try Argos BUSH units etc or Tesco larger stores have some perhaps a daewoo Setpal box best unit would be the £64.50 BT branded netgem.. online only IIRC
  3. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Thanks mate - this BT Netgem one good then?
    I was thinking of getting the Panasonic TUCT30 for £55 from Richer Sounds - know anything about it?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Crap remote ok out put BT net gem puts caller id on plasma if you want and .......... HAS component out via an optional cable Scart to 3 RCA cable (RGB pins)
    http://www.shop.bt.com/invt/011613
  5. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Crap remote eh? :(
    No use for the keyboard etc though really... might go for this panasonic one if its any use...
  6. Hefner
    Hefner
    Sep 29, 2004
    52
    Leeds
    My 1st post so be gentle.
    I got a Philips DTR-150 from Argos for £59.99 which is well specified for the money.
    http://www.argos.co.uk/webapp/wcs/s...atalogId=2501&productId=103308&clickfrom=name
    The main reason I got it was the fact it has a coaxial digital output (not stated on the website) so I can use a better external DAC.
    Better than the cheapy boxes for £50 anyway
    IIRC it can output s-video from the scart socket, which could be useful.
    :smashin:
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    didnt know philips would do S-video from second scart worth knowing...
    Panny has crappy remote credit card style thing..... Netgem has normal remote as well as keyboard (you dont need to use...)
  8. Hefner
    Hefner
    Sep 29, 2004
    52
    Leeds
    The remote on the Philips is fairly decent.
    It's around 14cm long and 5cm at it's widest point.
    I used a Goodmans box at a mates and the remote was terrible, the buttons used to stick and all sorts.
    I'm not sure if the Philips will be able to support 7 day EPG, but I hope it will :)
    Overall I'd say it's a decent box :thumbsup:
  9. Nelviticus
    Nelviticus
    Jun 21, 2003
    469
    Hitchin
    +68
    The NetGem is brilliant, and if you don't get the BT one you can add TopUp TV later if you buy a CAM. The BT one has the CAM slot disabled.
    Both versions also have a USB socket and built-in picture viewer, MP3 player and web browser, so you can hook them up to your internet connection - wireless, ethernet or dial-up - and/or play music and pictures on them.
    The only downside is that they don't yet have a 7-day program guide, so you only get "now and next". That'll probably be sorted out soon but there's no guarantee.
    Great box though, and it has optical digital output.
    Regards
    Nelviticus
  10. Nippy_Kangaroo
    Nippy_Kangaroo
    sorry for hijacking the thread Unlight :suicide:
    I'm in the same position as Unlight, I have a panny pw6 coming tommorrow and need a way to watch standard tv channels and was thinking of getting a freeview set top box as i have had no end of problems with sky in the past i dont want to go with them as its like talking to a bunch of trained monkeys when you phone customer services up.
    Is there a big difference in picture quality between sky digital and a digital freeview set top box (with a good reception) and what is tivo? is that like sky+? and any good?
    again... sorry unlight :blush:
  11. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Yes Freeview is better
    If you need component - Netgem
    Pace Twin is excellent
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Tivo is a PVR no longer sold in UK that will work all platforms sky, cable, freeview and analogue.....very clever bit of kit...
    For freeview watching on a PW6 i suggest netgem/BT... for recording i suggest pace twin... for bit of both Humax PVR800T
  13. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Cheers for the tips ;)
    Im taking an interest in the nice looking Sony box at the moment with the lovely, WF remote ;)
