Need a cheap sub or 5.1 speakers, help!!
Discussion in 'Home Cinema Speakers' started by andres99, Dec 22, 2004.
  1. andres99
    andres99
    Hi all,
    Complete no hoper needs some help!!
    I have at home a Yamaha amp that currently is connected to my XBox via a optical cable. The Amp has outputs for 5.1 sound, however at present I am only using 2 main speakers. What I would like to do is to buy a cheap set of 5.1 speakers and get them wired up. I've found somewhere that I can get the speakers, however I still need a sub, does anyone know where I could get a cheap one (under £100)??
    Andre
  2. Kazman
    Kazman
    Jan 14, 2004
    5,266
    Luton, Bedfordshire
    +139
    What are your current main speakers?
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I very much doubt whether you can buy a new subwoofer under £100 that will add anything apart from boom and distortion so I would suggest the second hand route where you may be able to find a reasonable Paradigm sub second hand at that price.
    Another alternative would be to buy a set of full range speakers and go without a sub for a while. Richer Sounds sell some reasonable speakers that aren't too expensive
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,515
    London
    +1,005
    It's hard to get a sub for under £100, can you stretch your budget?
