Quantcast
Need a cheap party amp
Big Adam
I’m picking up the speakers shown at the bottom of this post for £25 on Saturday.
I wanted some cheap loud speakers suitable for sticking in the garden for parties.
But now I need a cheap and dirty amp that will make the most of them. I’ll be using a HTPC or a CD-Player as the source. Anybody got any recommendations?
Specs of the speakers is as follows:
Frequency response: 50-20,000Hz
Power: RMS - 150w Music - 250w
Efficiency (1w/1w) - 95dB
8ohm
26 1/2" high
15" wide
12" deep
:lease:
Thunder
Cambridge Audio? second hand Rotel?
Big Adam
What power rating should I be looking at on the amp?
Thunder
With a 95db sensitivity and an 8ohm load it dosnt really matter most amps would drive em to a pretty loud level. A solid 50watt into 8ohm design from one of the two companies I suggested should be fine.
W
wookie
I would suggest a NAD integrated like a C320.
These amps can chuck out some real current and more importantly for you, they are equiped with "SOFT CLIPPING".
:D
Wasabi
Agree with wookie. Naad C320 are absolut superb with real dynamic watts, not marketing watts!!!
Wasabi
