R
Richard7
I am looking for a 32" LCDtv to use primarily with my PS3. I'll use it 95% for gaming on my PS3, and the other 5% for watching blu-ray movies, watching SD programs, showing pictures or other things. I want one because some games don't display correctly in SD and in non-widescreen. It doesn't have to be the best there is, I am only 16 years old and don't want to spend a fortune on the best tv out there, that's for when I'm older
, it's just to solve those issues, and to have a better picture. I want to spend something like 600-800 euro's.
I've been looking for some good tv's in that price range, and I found these:
-Sony KDL-32V2500: 880,- (bit out of my price range)
-Toshiba 32C3000: 665,-
-LG 32LC2R: 600,-
Are these tv's any good? I'm a bit in a dilemma cause I don't want to spend too much, but on the other hand it is a pity when I spend 600 on a tv that turns out to be not so good and to have problems. Then I'd maybe rather spend some more on a good future proof tv that I can use for a long time.
So, are the tv's I mentioned any good/sufficient for the things I'll use them for? In particular do they have ghosting or lag issues? Or if they're not so good can you guys recommend other TV's? I started looking at Tv's like the Sony KDL-32D3000 and the Panasonic TX-32LX70, but will those TV's really be worth the extra money? Will they really give me a better experience, or are the ones I mentioned good enough?
Thanks in advance, I look forward to your advice/opinions.
-LG 32LC2R: 600,-
