Need A Amp
cannondale99
Established Member
Looking at the info on the sub, it's 1000w max....ignore these ratings.
It's dual 2 ohm, so you're correct, wiring both voice coils in series will make your amplifier produce power at 4 ohms. Wiring in parallel will make your amplifier produce power at 1 ohm.
What are you using this subwoofer for? High volumes, sound quality? Anything with around 500w rms on tap at 4 ohms will be fine.....
Is this for the car, or are you building a sub for the home?
EDIT. If you're not sure how to wire in series, here's a diagram for you:
http://www.rockfordfosgate.com/rfte..._search_type=series&woofer_qty=1&woofer_imp=1
Gone were the days I used to run Resonant Engineering XXX-15 subs and DLS A6 monoblock amplifiers in the car. Two batteries, 0 guage cable, I think the MDF and subs weighed more than the little old Astra they were installed into. :(
blandy
so a amp at 500wrms at either 4ohm or 1ohm will be ok?? and i wont a mix realy between sq and volume. and it will be for my car.
blandy
one more question is it better to have a amp that runs at 500wrms at 1ohm or one that runs at 500wrms 4ohm?
just wondering if there is a performance difference?
cannondale99
Established Member
No performance difference really, more so for sub bass applications than full range. Obviously, you have to check that the amp is capable of running at 1 ohm in the first place.
If I had the choice, though, I would try and find something to run at 4 ohm.....there's less worry of things overheating....the boot was never a great place to store amplifiers in the first place.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
