Jon Weaver
I am a Plasma snob.. i still have my fleet of Panasonic Plasmas ranging from 32" to 50" and I still think they give the best pictures i have ever seen.
I have never been happy with LED/LCD screens so have be replacing my Plasmas with OLED.
I used to have one of my old 50" Plasmas on the bedroom wall, but have just moved house and there are no walls big enough.. The best I can muster is a 37".. But the problem is, it needs to go in a corner, and its really heavy.. So I am worried about fixing it safely. It also has a thick bezel which makes it bigger than it needs to be.
So I am tempted to change to something lighter with a smaller bezel and a 40" would fit. But as I said, I am fussy and whilst my argument that "its only a bedroom TV" is fine.. I guarantee that I will find fault and wish I had bought something better.. I was going to get the cheap JVC in Currys which is £200, but I am sure it will be horrible.
Its going to mount at head hight and whilst the mount I have bought has a 3" tilt, I am still going to be looking up at it, so I am going to need a decent viewing angle.
I am only feeding it with Sky and a Firestick, so I don't need any good "smart" capabilities.
Can anyone recommend a 40" screen with good sound/picture? I don't mind what it costs. I just want to be happy with the picture?
Thanks in advance for any recommendations.
