Need a 32" LCD for gaming.......suggestions please
mda96bjh
I want a panel both for my old consoles and the forthcoming next-gen machines....
Would be nice if it could also display a good PC image too........
So far I like the look of the Panasonic TX32LXD52/TX32LXD500
but i am open to any recommendations....
Many thanks
:lease:
W
will206
The TX32LXD500 is what I plan to buy and its main use will be with games, from what I've seen its an excellent screen. Hopefully it should be with me sometime around the 21st. I really wish I didn't have to wait this long!
C
clubber
Take a look at these...
Samsung - LE32R41BDX
HD Ready
32" Integrated Freeview LCD TV
1366 X 768 resolution
500cd/2 Brightness rating
800:1 Contrast ratio
170 degree viewing angle
SRS Tru Surround sound
DNIe (Digital Natural Image Engine) which improves Fine Detail, motion handling, colour response and contrast performance
Integrated Freeview tuner with 7 day Electronic Programme Guide
HDMI input
Component input
PC input (VGA)
2 X Scart input
Set Size (W×D×H) with stand: 797 x 249 x 650.7
Set Size (W×D×H) without stand: 797 x 99 x 592
Weight Net: 17.7
VESA 200*200(mm) standard fittings
OR
JVC LT-32DS6B
• 20W Total RMS Output
• CI Slot
• HD Ready
• Teletext: 1500-page Memory (Level 2.5)
• Graphical OSD
• Supplied with tabletop stand
• 2 SCARTs
• S-In, AV-In
• W-XGA (1366 x 768 pixels)
• IDTV (Integrated Digital TV Receiver)
• Slim-line Design
• HDMI Connection
• D.I.S.T. (Digital Image Scaling Technology) for High-resolution Picture
• Core components: High precision I-P Converter and Formatter
• Supporting components: Super DigiPure, IC with dedicated 32-bit CPU to process Dynamic Picture Management, Colour Management, Dynamic Black Level Control and Gamma Curve Control
• 1-tuner PAP (Picture and Picture)
• 12 Multi-picture
• Picture & Text Dual Screen
• 4 Speaker System with 2 Oblique Cone and 2 Bass speakers
• 3D Sound
• AHB (Active Hyper Bass)
• BBE(R) Sound System
• Component Input
• 170° Viewing Angle
• PC Input
Key Specifications
Panel: W-XGA
Resolution: 1366 x 768
Contrast Ratio: 1000:1
Brightness: 500cd/m2
Response Time: 7ms
Dimensions (inc. tabletop stand)
Width: 80.8cm
Depth: 22.5cm
Height: 61.1cm
Weight
20 kg
These two seem like the most popular choices and i also want to know which one to get for using 360 and SKY + !!!
Eiji
The JVC LT-32DS6B 'seems' the better choice but is also atleast £160 more expensive so you have to ask yourself if the differences in the JVC compared to the Samsung ie 1000:1 contrast ratio on JVC vs 800:1 on the Samsung amongst other differences warrants the additional money from YOUR pocket.
Trending threads
