Need a 28"/32" Prog Scan TV, recommendations appreciated!
Discussion in 'General TV Discussions Forum' started by phresh, Feb 13, 2005.
  1. phresh
    phresh
    May 10, 2004
    215
    Oxfordshire
    +3
    I've given up on LCD's and Plasmas (cost and other issues) and the Sony LCD RPTV's (viewing angle) so have decided to settle on a good old CRT TV.
    The one feature I need (and my reason for originally going for the above) is that I want progressive scan. Currently for use with my US Gamecube and PC (DVI > Component) and in future using my PC as a scaler for non 480p sources.
    So basically i'm after recommendations for a 28 or 32 inch widescreen CRt with good preogressive scan. The only other thing is the TV's depth....preferably 50cm or under.....
    Just as a side question has anybody connected their PC's up to a CRT using prog scan, and if so was it any good?
