Question Need 6-7m HDMI 4K Cable
Discussion in 'General TV Discussions Forum' started by richardc1983, Jan 12, 2019.
  1. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    Hey all, I am wall mounting my LG B8 65" TV and need a new longer hdmi cable minimum 6-7m long but needs to support proper 4kS HDR. The existing one doesnt allow deep colour to be turned on
    Seen these on Amazon
    A
    AmazonBasicsHigh-Speed HDMI 2.0 Cable - 7.5m / 25 Feet (Latest Standard) Supports Ethernet, 3D, Audio Return https://www.amazon.co.uk/dp/B014I8TC4E/ref=cm_sw_r_cp_apa_i_SuDoCbFHJS1G3
    Will this do the trick?
    Thank you
  2. Russ_64
    Russ_64
    Jan 20, 2005
    433
    2
    46
    London
    +155
  3. keylion
    keylion
    Oct 13, 2002
    227
    Lancashire
    +18
    It can be hit and miss at that length and what has worked for one person might not work for you due to variations in equipment.
    You're best to order it and try it. At least with amazon you've got an easy return if it doesn't work.
    I've been struggling with an 8m length passing 4k at 60hz 4:4:4. I ended up getting g a Ruipro fibre cable from TMF in the end. The biggest problem I had was coming to terms with paying so much for a cable.
  4. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
  5. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    986
    +255
    I have a 15.2m Amazon Basics HDMI cable which works fine for 4K :)
  6. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    Yes I get 4k and HDR but deep colour in the TV won't work so it struggles on the existing cable.
  7. Audi0Newbie
    Audi0Newbie
    Aug 2, 2018
    63
    11
    Glasgow
    +5
    It’s your call but i wouldn’t touch Amazon basics there stuff is okay but you can get way better for a couple extra pounds or dollers
  8. GeneticMutation
    GeneticMutation
    Sep 7, 2011
    642
    46
    +212
  9. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    Sorry, but better in what way?
    If the cheaper option works then why is spending more money better?
    I'd ordinarily suggest Amazon's own Basics cables which are both affordable and dependable, but this is based upon using shorter lengths than the one required. The length needed is very close to the maximum limit HDMI org suggest shouldn't be exceeded (8m). Also note that HDMI org do not certify any cable longer than 8m as being HIGH SPEED (18Gb/s), but this isn't to say that cables that are not certified aren't as good as those that are. Shorter lengths are less prone to dropouts and other issues though.
    The price of a cable will not ensure its reliability or its abilities. Some of the more expensive cables have even proven to be less reliable than cheaper options when tested alongside one another.
  10. 1crb1
    1crb1
    Jul 21, 2009
    112
    28
    +35
    If you get hdr then deep colour must be working?
  11. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
  12. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    There's an option to have it in a higher bit rate on the TV so I think its 10 bit or something?
  13. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    The cable cannot influence the bit depth. The signal would simply not be conveyed and dropout if the cable hadn't the bandwidth to carry it the distance the cable covers and the video signal wouldn't be downggraded in order to allow the cable to carry it.
    You usually have to enable the wider colour space abilities on each of a TV's HDMI inputs if wanting to accept and portray HDR video sent to the associated HDMI inputs on that TV.
    You can see how this is done on various makes of TV here:
    How to enable HDR for Xbox One X on popular 4K TVs
  14. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    When I enable the wider colour space abilities in the hdmi settings on the TV I get a black screen so it's as if the TV isn't supporting it.
    HDR is working though but I hear there's different bit rates?
  15. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    Such as 8bit HDR or 10 bit HDR?
  16. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    It is the colour bit depth and not the bit rate of transfer. You technically need to be using the REC 2020 colour space if wanting to portray HDR and you'd ideally need at least a 10 bit video panel to do this. Most lower end LCD 4K TVs advertised as being HDR compliant are actually only 8 bit panels though and they use interpolation to try recreate the effect of a 10 bit panel.
    You may find this informative:
    4k HDR - 8 bit, 10 bit, 12 bit, and all the bits you need to know
  17. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    You cannot get HDR without enabling the wider colour space handling abilities associated with the associated HDMI input the signal is being sent to.
    When you enable HDR or Deep colour on the TV then the source detects that the TV is able to accept an HDR signal. This signal unfortunately requires more bandwidth to convey along the cable than a non HDR video stream. The TV is in all likeliehood not receiving the signal and the signal is being dropped by the cable which is unable to get it to the TV?
    The solution is to use better cabling or convey it via another means of conveyance such as HDMI over fibre.
  18. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    The TV comes up with "HDR" when I put 4k HDR on but the setting under hdmi when I enable that just shows a black screen on hdr content. I have to leave it off .
  19. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    You have to do the following with a LG UHD TV in order to be able to portray HDR video being sent to it:
    1. Press the Settings button.
    2. Scroll down to All Settings.
    3. Navigate to the General tab.
    4. Select HDMI ULTRA HD Deep Color. Each of the available HDMI ports should now be listed on screen.
    5. Enable the feature on the ports of your choosing.
    Note that some of LG's TVs only have one HDMI that can accpt HDR so not all the HDMI inputs may have the option to turn on UHD Colour?
    Note that if you do not enable this for the HDMI input you intend to send HDR video then the source will not send HDR to that port.
  20. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    It's detecting HDR as the TV says it on the screen. I have that option turned off though.
  21. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    If you have the option dissabled then the source will not be sending HDR metadata to your TV via that input. That option has to be enabled on that input if wanting to send HDR metadata to the TV via that input.
    To use HDR on your display, you'll need to turn on "HDMI ULTRA HD Deep Color" within your TV's settings.
  22. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    Sorry yes it is turned on but there's also an option in Kodi called "auto colour depth switching" with this enabled by default when I try to play 4k hdr I get no signal coming up on the TV.
  23. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    I'm not familiar with Kodi, but I'd suggest the issue may be with that device as opposed to your TV or indeed the cable? Do you have another source such as a UHD disc player that you can use for testing purposes? See what using such a player to output HDR video results in?
  24. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    No I'm afraid not. With the option deselected in Kodi 4k HDR plays. People are saying it may be playing in 8 bit though instead of 10?
  25. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    I think KOdi has had major issues with HDR in the past. No idea about current builds though?
  26. richardc1983
    richardc1983
    Aug 14, 2008
    969
    Leeds
    +70
    Wondering what the refresh rate should be set to for 4k?
  27. dante01
    dante01
    Mar 5, 2009
    44,915
    +10,554
    Refresh rate?
    Refresh rate is something determined by the display and is a hardware capability. Video content would have a frame rate and not a refresh rate. The refresh rate of a monitor is the speed (rate) at which the monitor’s image changes (refreshes). The faster the refresh rate, the more times the image can update every second and the smoother the image will look. This number of changes per second is measured in hertz (Hz). Video isn't encoded with this and the refresh rate is not determined by the video being portrayed.
    How Are Video Frame Rate and Screen Refresh Rate Different?
  28. linnasak
    linnasak
    Sep 13, 2007
    330
    Scotland
    +83
    Spent a load of time testing higher quality passive cables at 4m 5m and 6m via AVR to 4K projector and direct from source to projector. Some sources ok others refused to do hdr or 10bit. Example uhd Blu-ray ok except menus. Xbox uhd Netflix not, Apple TV 4K ok but not HDR if not direct. Basically some sources use higher bandwidth and fail. Also had issues with HDCP handshake where picture would go black for couple of seconds.
    In the end got one of these
    Monoprice SlimRun AV HDR Cable... https://www.amazon.co.uk/dp/B06XRNQ4YM?ref=ppx_pop_mob_ap_share
    Active Fibre, just works, and I could route so unseen. Suggested by projector dealer as the one he carries that just works everytime. Still use passive to 4K tv seems fine but only 3m!
    Kevin
  29. linnasak
    linnasak
    Sep 13, 2007
    330
    Scotland
    +83
  30. GeneticMutation
    GeneticMutation
    Sep 7, 2011
    642
    46
    +212
