NEC Vt540 connection woes
Discussion in 'Projectors, Screens & Video Processors' started by mattcullum, Feb 16, 2005.
  1. mattcullum
    mattcullum
    Feb 16, 2005
    71
    Ipswich
    I've just upgraded from an all-in-one Sony to a new separates system. This has meant a
    new toshiba 340E dvd player which I bought believing it to have S-video out - however
    it doesn't it.
    So can anyone shed any lighton how to connect this up to my projector?
    The toshiba 340E DVD player has scart (rgb) out and component (3x rca)
    out (Y, Pb, Pr) .
    I need to connect to the NEC VT540 D sub connector this accepts RGB and
    Cr, Y Cb sync on green.
    Can anyone please help? This is driving my mad -all this new kit and I don't know
    how to make it all work!
    HELP
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,087
    UK.
    +3,488
    Doesn't it take component via the d-sub connector or isn't there an adapter for it?
    Can you get s-video from the scart output from the player? If so, you just need a scart to s-video lead, or a rgb scart to s-video adapter. The adapters can cost more than the player though.
    Gary.
  3. mattcullum
    mattcullum
    Feb 16, 2005
    71
    Ipswich
    Nope friad not no s-vid through the scart, since the projector will accept rgb if itspossible to use this, then I expect thats the best route....unless someone more wise then me tells
    me otherwise!
    Best
    Matt
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,087
    UK.
    +3,488
  5. mattcullum
    mattcullum
    Feb 16, 2005
    71
    Ipswich
    Thanks, any idea of the pin-out of such a cable? I need a long one
    (like 10M) and am frightened to ask NEC how much they want for
    such a beast!!!
    Matt
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,087
    UK.
    +3,488
    It's possible that it's just a short cable, so all you need to do is buy a female to male vga cable to connect it to, or a male phono to female phone component cable. Having two cables instead of one isn't ideal, but I doubt you'll see a diference in picture quality.
    Without doing a web search I couldn't tell you the pin-out, but if the cable isnt that expensive, you could always test for continuety between each pin and component cable so that you know what cables went where.
    Gary.
