NEC VR5 connections
Discussion in 'Plasma TVs Forum' started by philthyanimal, Jan 25, 2005.
  1. philthyanimal
    philthyanimal
    I'm about to order an NEC vr5 but just a quick question.
    The 5 BNC inputs. I know to use a sync blaster scart to 5 bnc cable, but was just wondering if i could use an rgb to component converter and use an rca to bnc component cable out of the converter?
    Oh, and whats the DVI input like on the NEC?
  2. pajare
    pajare
    Jan 21, 2004
    155
    LEEDS
    Just ordered my NEC42 VM5 from the very helpful Matt at Nexnix.If you are ordering from them he can tell you what cables you need for the gear you are going to connect and also supply them. I have ordered a HDMi to DVi cable ( for Pioneer 868i DVD ) and a scart to RGBS ( 4 BNC to scart for NTL cable ) on his advice.
    Cheers-----Will
    By the way Nexnix do a nice desktop swivel stand that is much neater than NEC one.
  3. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,110
    Norwich
    +790
    The NEC units can take a scart input (well, RGBand composite sync).
    You can either input this on the BNCs or you can input it on the vga input.
    So £20 cable and no transcoding to be done, so you should get even better results.
  4. Mojito
    Mojito
    Mar 11, 2004
    192
    2
    Moscow
    +3
    If you are ordering VR5, don't buy HDMI-DVI cable, it is supplied with the screen. Just in case ;)
  5. philthyanimal
    philthyanimal
    so the view here is one of those scart to 5 bnc cables is my best bet.
    Anyone recommend a good one?
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,110
    Norwich
    +790
  7. peezee
    peezee
    d'you have a link? Can't find a pic of the stand on the Nexnix site. The base NEC plasma "feet" are just horrendous, totally ruins the nice design effect... :eek:
    Does the swivel stand look s'thing like this below?
    [​IMG]
  8. pajare
    pajare
    Jan 21, 2004
    155
    LEEDS
    Yes I think thats the same one only mine will be black to match VM5
    Regards-----------Will
  9. peezee
    peezee
    neat, thanks! :)
  10. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    115
    16
    You don't need 5 BNC's.
    You need scart to 4 BNC (RGB+Sync)
    One here too http://www.lektropacks.co.uk/dept.asp?dept_id=201
    SCART OUT 4 X BNC (Red/Green/Blue/Sync)
    Order Code:- PSCRGBSO
    Regards
    Andy.
  11. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    I'm also hoping to order one of these from NexNix soon.
    I would be hooking an NTL Digital Box to the screen so I presume I should go with that SCART to 4 BNC (RGB+Sync) for that.
    Should the PQ be good with that?
    What about auto screen size switching for different wide-screen broadcasts?
    Then I would also be hooking a DVD player to the screen.
    Would you suggest I use component for that or would a DVD player than can output DVI be better?
    I have yet to buy a DVD player so am in the market for a decent Progressive Scan (and Region Free) player with a good video output type to hook to the VR5.
    Any suggestions :lease:
    Cheers.
    Ciaran.
  12. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    115
    16
    Fozz, I went for the Panny DMR-E85 DVDR.
    If your going to get a DVD you could go:
    NTL scart > DVD scart > DVD out to plasma via 3xRCA - 3xRCA component cable, you would need to keep your DVD on to watch TV.
    If you want your DVD in standby whilst watching TV, then you would also need the scart > 4BNC lead to connect NTL box direct to the NEC.
    Regards
    Andy.
  13. lawrenso
    lawrenso
    Oct 6, 2003
    1,155
    48
    Flintshire
    +35
    Fozz/Ballistix
    If your NTL Box has pass through (SKY + has), do it the other way round - DVD-NTLBOX-SCREEN, and you will not need to have the DVD on to get the signal. If the DVD is on to get a signal, it will be the DVD Signal, you need something that passes through when in standby/off
    Lawrenso
  14. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    hey guys, just leaning towards a nice VM5 right now, can you just advice on these connections.
    is there an audio out? i want to use 2 unpowered speakers so i don't have to turn on amp every time (usually pop in and stick news on at lunchtime).
    i have an xbox which is not chipped (UK). what's the way to connect? i have at current just scart with optical lead into my amp on it.
    i need a dvd player and also may switch from ntl to sky+.
    so there's three main connections where i can only see a way of connecting two devices from what i've read. but i know little so any advice would be appreciated.
    oh, and i have a NAD T752 amp for what it's worth.
    thanx
    ps. like that stand better, looks like i'll be nexnixing soon :thumbsup:
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    but means recording in composite only and no RGB>component conversion (but fine witha DVD player)
  16. lawrenso
    lawrenso
    Oct 6, 2003
    1,155
    48
    Flintshire
    +35
    I bow to your wisdom Hornydragon, as I said I use Sky+ which has RGB passthrough on it, and my DVD Player at the end (won't be watching Sky if watching a DVD). I do have a DVD Recorder, but admit this is quite redundant now that I have SKY+ (I am a true Sky+ believer - even my wife can use it after a fasion :D :D
    lawrenso
    PS Can't wait to hear your review of your megatest :smashin:
  17. peezee
    peezee
    back to the swivel stand thing... called "NEC OnLine" France today (not sure they actually belong to NEC) who tells me the swivel stand only comes in silver - not in black. This confirms what retailers tell me.
    Are you 100% positive you're going to get a black swivel stand for your 42VM5, or this thing below (Ref. 6925660000?) instead...?? :confused: :eek:
    [​IMG]
  18. pajare
    pajare
    Jan 21, 2004
    155
    LEEDS
    Hi Peezee
    Plasma and cables turned up today but the stand they sent was the black NEC one. I phoned Matt Gee at Nexnix and after checking up he confirmed the swivel stand is only available in silver, so I am getting the silver swivel stand and will probably get it sprayed to suit.
    Regards ----Will
  19. peezee
    peezee
    sh.t ! That's what I feared... :suicide: Well, thanx anyway.
    Hmm, not sure I will want to do the spraying thing on an elegantly designed stand (but I'm sure I don't want the ugly looking black "stand on its feet" either :blush: ).
    I usually leave a little dim light when watching movies on TV (i.e. not in a dark room), wonder if the silver bezel could be an issue compared with a black bezel (contrast et all...)... :confused: Anyone cares to comment on silver vs black bezel vs pic quality?
    OTOH the vast majority of "design" TV stands (ya know, glass and metal) do have silver parts, not black, so... Looks like the choice is going to be b/w silver or else... silver! :rolleyes:
  20. Duffers0
    Duffers0
    My school boy error.
    Nexnix supplied my RGB Scart to 4 phono lead and 3 BNC adapters. Gave me instructions to RGB on the BNC inputs and sync on the composite video input.
    Beaware you can only sync on the HD BNC or the BNC video input (1)
    Been bl**dy watching composite for the last 3 weeks, wondered why the Sky picture was so rubbish!!
    Bought another BNC adapter and found sync on the HD bnc slightly better, or imagined it was better!!
    RGB bit more noisy than composite but better edge definition and less of that horrible false contouring.
    I am still fiddling with settings all of the time to try and improve Sky anybody feel they have a good setup on the VR5??
  21. nheather
    nheather
    Oct 6, 2004
    16,913
    167
    Horsham, West Sussex
    +6,168
    Can anyone confirm the complete set of inputs available on the VR5. From this thread I can gather
    (a) R + G + B + CompSync
    (b) DVI (or is HDMI)
    (c) VGA
    Are there any others - what about component ?
    Is it still better to use SCART>VGA (like with the Pany) or is RGB + Sync just as good ?
    Cheers,
    Nigel
  22. Loada
    Loada
    Mar 4, 2003
    591
    Guisborough, North Yorkshire
    +51
  23. philthyanimal
    philthyanimal
    duffers, are now using a scart to 4 bnc adapter?
    Don't you need a "sync blaster" scart to 5 bnc?
    I'm still a little confused
  24. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    can you believe i've only gone and ordered the alpahason elegant piano black plasma stand!!! to go with my black nec and black stand (not the nec one).
    so if they haven't got a plain stand, hmmm. are those feet really that bad??? may have to get silver nec on my nice black stand. goddamit :thumbsdow
  25. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    115
    16
    Sync blaster not needed m8.
    NEC accepts RGB+Sync on the BNC component input.
    Andy
  26. philthyanimal
    philthyanimal
    So one of the van damme scart to 4 bnc's from avsales would do the job?
    the nec has the rgb + h and v. I take it this is horizontal and vertical(probably wrong) which one is the sync?
    Sorry for the dumb questions but i'm ready to order for next week as i'll be off work and want to install it then.
  27. peezee
    peezee
    Vipen, far as I know the 42VM5 on its black stand should look like this:
    [​IMG]
    while the 42VR5 on its newly designed stand (model above also exists in silver btw, gotta be careful when ordering) should look like this:
    [​IMG]
    It's all a matter of taste of course, so though I have a strong preference I won't comment :D , other than the silver stand is of swivel type, can be very convenient at home. Too bad it's not available in dark grey... :(
    I'm not 100% sure that the above is fully accurate (I'm not a NEC retailer after all) so I'd suggest you check all this with yr vendor before making any decision, don't want to be causing any unnecessary trouble here... ;)
  28. nheather
    nheather
    Oct 6, 2004
    16,913
    167
    +6,168
    Loada
    Thanks very much for the manual. If I understand it correctly it has the following connections:
    RGB1 - (D Sub) RGB + Green or Composite Syncs
    DVD1/HD1 - (Phono) Component
    DVD2/HD2/RGB2 - (BNC) Component or RGB + Composite Sync
    DVD3/DD3/HGB3 - (DVI-D) Don't really understand this one
    So with Sky+ (RGB SCART), Freeview (RGB SCART) and DVD (Componet) does this mean I could connect them as follows and not need an external switch box
    DVD > DVD1/HD1 (Need a phono to phono)
    SKY+ > RGB1 (Need a SCART to 15 pin Sub-D)
    Freeview > DVD2/HD2/RGB2 (Need a SCART to BNC)
    Cheers,
    Nigel
  29. peezee
    peezee
    Btw, found out last night on the US AVSforum that there are more differences b/w the silver VR5 (consumer oriented) and the dark grey VM5 ("Pro"). Can't trace back the exact post but I kept a copy of the rather complete list of these differences (see below).
    So it's not just about the colour or the plasma stand, the VR5 definitely has attributes that are more specific to a home usage, while the VM5 has many capabilities that really only apply in a Pro environment (public dispplay, entreprise, ....). Very interesting that post, many thanks the guy/gal who wrote it, whoever he/she is... :)
  30. Duffers0
    Duffers0
    If using the BNC's then sync on either H (horizontal) or video connect no 1 (again the BNC one at the top).
    This equates to either scart 1 or 2 in the BNC connector setup menu
    Basically the BNC's can be used for either RGB or component depending on choice in the setup menu. :thumbsup:
