NEC VR5 and Powerstrip
Discussion in 'Plasma TVs Forum' started by leo31773, Mar 9, 2005.
  1. leo31773
    leo31773
    Hello
    Has anyone managed to get a true 1:1 image on the Nec VR5?
    I've been playing with Powerstrip for hours with no success.
    Thanks,
    Leo.
  2. leo31773
    leo31773
    No one...?
    :lease:
  3. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    Have you tried the ones listed in the manual:
    848x480, 60Hz vertical, 31kHz horizontal with RGB select on wide 2
    and
    852x480, 60Hz vertical, 31.7kHz horizontal with RGB select on wide 1
    Note sync polarity on these is different so if one doesn't work perhaps the other will. Also can you graphics card output these?
  4. leo31773
    leo31773
    Yes I did try the settings in the manual. graphics card is Radeon 9800 Pro and the image displays fine on the LCD.
    I did find out today that I had the ATI scaler enabled, which kind of makes Powerstrip's settings irrelevant.
    After disabling the scaler in the Catalyst control panel, and choosing 848x480 in Powerstrip with discrete timing, the image looks better, but still not 1:1 (some text distortion and desktop is being cut a little on the left side).
    Trying to reach the correct timings for the Nec, result in a blank screen or system crash.
  5. Loada
    Loada
    Mar 4, 2003
    593
    Guisborough, North Yorkshire
    +51
    I think you're trailblazing here so good luck - we'll all be interested to see how you get on.
  6. leo31773
    leo31773
    SUCCESS!
    Thanks to the very professional help of Rik from the Powerstrip team, I can now get a perfect 1:1 image on the VR5.
    It seems I didn't know I had to setup multiple monitors in the Windows display settings... Once I got that, it took 5 minutes to setup a perfect 848x480 signal to the plasma.
    I recommend everyone who's going through this frustration to read my discussion here with Rik:
    http://www.entechtaiwan.net/forums/viewtopic.php?t=2257&sid=f266e61074940228a446d3f3fbfa2ab2
  7. MIGHTYrog
    MIGHTYrog
    Jun 11, 2003
    929
    28
    Towyn, N.Wales
    +31
    I'm still having trouble getting a 1:1 pixel mapping for my VR5 anychance you could explain in depth what settings are required and EXACTLY how you did it? Its really doing my fruit in :-( (I have a Radeon 9250 Gfx card so settings should carry across)
    TIA
    Roger
