NEC VR5: [email protected] works fine
cj
Well fed up with all the recent negativity on this screen I pulled in my Crystalio from my projector room, hooked it up to my NEC VM5, switched the output resolution from [email protected] to [email protected] and got a picture right away. It was initally offset compared to the 60hz signal, but after about 30 seconds playing with the settings we have a great picture, with no FRC.
In fact we're all currently watching the Arsenal vs. Man United game at [email protected], and no one's complaining one bit :) I even used the Sky+ box via S-Video (and not SDI) and the picture looks fine.
Bear in mind I own both a Panasonic PW7 and a NEC VM5, so am not trying to validate my purchase - I like them both :)
The VR5/VM5 DOES accept [email protected] via DVI, and the PW7 currently does not.
P.S. Cracking game - now 2-3 to Man United.
hornydragon
cj interesting looks like there is more work to be done here. Particulary with the XR3/XM3 screens
cj
Well IMO the VM5/VR5 is a cracking screen and doesn't deserve the negative press it's been getting here in the last few days. It's cheaper, comes with far more connection options than the PW7 - you can even connect it via RGB SCART according to the manual (with the right cable) - and has a far better chance of being compatible with Sky HD at the moment than the PW7 (which currently has NO chance via DVI unless you shell out nearly £1000 on an external scaler).
Yes the PW7 is a great screen also, and people might prefer the picture to the NEC, but there are just so many factors involved in getting a "better picture" and I think having a level playing field when comparing them is nigh on impossible.
Yes I've had the PW7 (and PW4 before that) in MY living room, fed with MY sources, setup by ME. I'm a long way off from being an expert, but my family and I have over 5000 hours "normal" viewing on the Pannys, and we're just as happy with the VM5 currently on the wall, and equally my parents' are enjoying my PW7 on their wall.
Taz69
Excuse my ignorance CJ, but what is the "Crystalio" ? and what does it do to enable the NEC to display 720p/50 ?
Taz
Taz69
Gordon @ Convergent AV said:
it's a scaler. It takes in one resolution and sticks out another...CJ has set his to stick out [email protected]
Gordon
Cheers m8, does that mean to display 720p/50 on the NEC, I would have to buy a scaler like the PW7 needs, making it another grand on top or ?
Taz
cj
Here we go again :)
No it doesn't - I was just using my Crystalio to output a 1280x720/50 signal as I don't have any other device that is capable.
The PW7 currently cannot accept a 1280x720/50 signal via DVI and you would have to buy a scaler to convert the 1280x720/50 signal to a 1280x720/60 signal that the PW7 does accept.
We still can't conclude that the NEC will 100% be able to display the output directly from the SKy HD box via DVI - we won't know until it makes an appearance and someone tries it. But the PW7 currently has no chance, unless you buy a scaler.
AVForums Sponsor
Not necessarly. CJ did this test as there has been some speculation that NEC are falsely advertising the [email protected] compatablity of this panel. The reality is that [email protected] can take many forms......and those testing so far have not been able get the panel to sync with their sources. We'll have to wait for HD [email protected] to find out definatively about compatablity with SKY HD but for now we know it's more than capable of working....given a little time and patience.
Gordon
Taz69
Cool, thanks Cj and Gordon, I know its been played to the death about this HD compliant etc, but at least it sounds promising
Thanks for your replies guys
Taz
BALLISTIX
Gordon
Gordon, NEC do not advertise that the VR/VM will work at [email protected], just thought I'd point that out.
Regards
Andy
hornydragon
just to put onw thing to bed it was the XR3 that i tried to view [email protected] (more important that the HD panel accepted HD signls to my mind) and it would work at 50Hz ran out of time to test the VR5 unfortunately..... If people actually read the test results (long i now i wrote them) instead of scanning the text and picking on small bits and misquoating we wouldn't have half this mess.....
BALLISTIX
Onto another point, even though it does'nt concern me personally as I doubt I'll be getting sky anytime soon.
I'm no expert so could someone explain?
Even if the VR/VM did'nt accept [email protected] properly, could you not send it to the panel and let the panel convert it to 60Hz as it does on std settings? or is there more to it than that?
Andy.
cj
Well I guess the "confusion" might come from posts like this from the "PW7 vs. VR5" thread: -
hornydragon said:
OK guys the NEC manual has NO support for 720p @ 50Hz FACT.
If it works bonus, but it will not be plug and play........I tried that it didnt work.
This is from the "PW7 vs. VR5" thread (and not the "PW7 vs. XR3" thread). When you say "I tried that it didnt work." I assumed you'd actually tried it and it didn't work. My mistake :)
Anyway - mostly all cleared up now :laugh:
hornydragon
yes it seems i got my NEC model numbers slightly mixed up... Still isnt in the manual...but if it works great just a shame about the PQ IMO
P
peezee
hornydragon, you NEVER give up - do you? :suicide:
cj, thanks a lot for clarifying this - yet again - and making it a clear thread title helps too. :thumbsup:
Joe Fernand
AVForums Sponsor
NOTE TO MODS
Please insert a NEW Rule in CJ's profile -
Rule 01. I must NEVER post the result (or mid game score) from any big matches that Joe is recording to SKY+ to watch later in the evening :)
Best regards
Joe
Joe Fernand
AVForums Sponsor
Morning CJ
Luckily enough it was still well worth watching the match!!!
Its always the 'sources' you least expect that catch you out when your time shifting the footie I find.
Best regards
Joe
Loada
To be fair, HD, it was MAW's initial write-up that implied both NEC panels had problems - although it was actually talking about the XR3. I think one of the good things coming out of the mega-test is how the VR5 has risen, phoenix-like, from the ashes of the XR3 testing and has generated a lot of discussion, much of it positive and will perhaps attract a following (in much the same way as the LG PX11 has) due to its overall features and price - competition is a good thing for the UK plasma market in general - it means better (and cheaper) screens for us all.
KHCC
Mornin'
Due to time constraints,as Hornydragon stated, we couldn't test the VR5 with 720P @ 50Hz. I have since played with it and can confirm that the VR5 will take 720P @ 50Hz on the DVI input.
Regards
Latest News
Technics announces SL-G700M2 SACD and music streamer
  • By Ian Collen
  • Published
The Amazon Prime Early Access Sale 2022: 11-12 October
  • By Ian Collen
  • Published
Google set to launch the Pixel 7 and Pixel 7 Pro smartphones
  • By Ian Collen
  • Published
Focal launches Bathys noise-cancelling wireless headphones
  • By Ian Collen
  • Published
Formovie Theater UST projector hits the UK
  • By Ian Collen
  • Published
