Nec vp4 owners
Discussion in 'Plasma TVs Forum' started by john R1, Nov 16, 2003.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    What connections do you use for your sky or cable digital what sort of pq do you get, would be using the component for my dvd
  2. RossC
    RossC
    Feb 13, 2003
    144
    john,
    There's two component inputs - one labeled as DVD and the other I can't remember the labelling, but it's the 5 BNC connectors - simply config it thru' the menus and use just three of the terminals...
    So i've got DV27 direct into component and RGB out from Twin into JS RGB-YUV convertor to component input.
    HTH
