nec projector. Lamp availability?
Discussion in 'Projectors, Screens & Video Processors' started by Sandman, Sep 25, 2003.
  1. Sandman
    Sandman
    Nov 28, 2002
    3,555
    Glasgow
    +1,270
    I have seen an nec projector for sale but been informed that the lamp needs replacing. I dont know much about projectors so could someone please tell me if it is easy to replace these lamps and if so are they expensive?
    thanks and sorry for not having any more information.
  2. Mirablo
    Mirablo
    Jan 16, 2003
    70
    fairly easy (might depend obn the PJ)
    depends what you mean by pricey , youre going to be talking £x00`s again depends on the PJ
    do you trst the seller . i personaly would be wary of buying without being able to see it in all its glory before shelling out (plus buying the lamp)
    just my 2c
  3. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Sandman,
    If you indicate which model you've been offered and what price (roughly), ppl might come back with advice - someone might have had the same PJ, opinions on whether it's suitable/a good deal.......................
    2 more cs
    Sean G.
  4. Sandman
    Sandman
    Nov 28, 2002
    3,555
    Glasgow
    +1,270
    it was a SG800T (i think), I have searched around on the net and found that it was designed for computer use, I was offered it at £200 but it needed a new lamp and I found these cost about £300. I decided not to bother as I think it was a 4:3 aspect ratio and I would only want a 19:9.
    Thanks guys
