NEC Plasma
Discussion in 'Plasma TVs' started by abeautifulmind, Mar 25, 2005.
  1. abeautifulmind
    abeautifulmind
    Any body has any experience with NEC 50XM4a 50 inch HD Plasma display panel ? Are NEC panels better than Panasonic or Sony ? This particular model (50xm4a) seems to have a wide variety of inputs (screen resolution also) compared to its Sony/Panasonic Counterparts.
  2. MavAV
    MavAV
    Jan 17, 2005
    194
    28
    West Yorkshire
    +44
    I have the domestic version of the XM4 and am more than happy with the black level and the colour rendition. However as to whether the panel is better than the Panasonic or Sony can only be decided by seeing the panels for yourself. The Panasonic will have better blacks than the XM4 but at the expense of brightness. You might want to try www.avsforum.com as there are a lot more NEC plasma owners over the pond, some of which may have looked at the Sony panel.
  3. abeautifulmind
    abeautifulmind
    Thanks foryour reply!
