NEC plasma cutting out
H
huggybear2
I've got an old model 50" NEC plasma. Works a treat, but every now and then it cuts out automatically into standby mode. I've double checked (1) Not overheating (2) Always a video signal present (3) Timer off.
Any ideas pls??
symanski
Does the time to switch off vary??
If it does, it does sound like a heat or tolerance fault, and possibly related to power supply shutting down for some reason. Only option really is to talk with NEC.
All the best,
Dr John Sim.
H
huggybear2
Thanks for that.
Yes the time to shut off does vary - so I think you're probably right ie it is a tolerance fault.
I've spoken to NEC - costs an arm and a leg just for an evaluation!
Regards
