Nec np100g
Breers33
hi , i have just purchased three of the NEC NP100G projectors for staff at work in order to do traning/presentations, it comes with a wireless remote which is working fine apart from there seems to be no button to move a presentation onto the next slide?, the manual does not cover this and the only button i could assume is the enter button but no avail so the only way to progress slide show on is to use the enter button on the laptop which isnt ideal, does anyone know if there is a way to do this?.. thanks..
Barcoing Mad
You need a wireless remote control/mouse for the laptop. The remote with the projector is presumably just for controlling the projector, not the arbitrary source which is feeding it.
