Nec Ht1000 ghosting effect
Discussion in 'Projectors, Screens & Video Processors' started by jacs0046, Sep 21, 2003.
  1. jacs0046
    jacs0046
    Hi just install my new Ht1000 ,with 25 feet of high grade component video cable,and i noticed an obvious ghosting effect , easy to see on letters in main titles of movies.Any owner of Ht1000 has had that problem ?
    Jacs
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,150
    UK.
    +2,670
    I don't get that on mine - what films is it on? It could be Edge Enhancment which is added to some DVDs so that edges look sharper on smaller tvs.
    I use 10m Profigold component cable (£28+ VAT from CPCs), but I didn't get it on their 5m cheapy cable either (< £5 +vat), so I don't think it's your cable.
    Is the ghosting all around, or just to one side? Have you tried the other inputs such as s-video or composite from the same player? Some have EE built in as a 'feature' so that might be the culprit. What player is it?
    Gary.
  3. Kramer
    Kramer
    Never experienced that either during my spell with the HT1000.
    Echo what Gary has said. Eliminate the cables as a possible problem & try with different sources etc..
    I'm sure you'll have it sorted very soon.
    :smoke:
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Echo the advice about trying different cables...... also check cable routing etc.
    You should also check the brightness and contrast settings on the PJ - a calibration with Avia or similar never goes amiss, though the HT1000 should be good to go out of the box.
    Sean G.
