NEC Green light spells nothing!
Discussion in 'Plasma TVs' started by craigz, Mar 25, 2005.
  1. craigz
    I have an NEC 42 pd2 display which has been working fine for a while, then suddenly I have only the green power and nothing else - no on screen menu , not picture and no fan noise! The 2 internal 10amp fuses are fine and accoring to the manual the power lights would flash if there was a major issue. I had a tip to look at a for a resistor q17 on the power board but can not find this. Anyone got any info/tips/ ideas what the problem might be?
    Thanks in advance
