Nec FS68V81S Intermittently won't work.
Discussion in 'General TV Discussions Forum' started by Horseradish, Apr 30, 2007.
  1. Horseradish
    Horseradish
    NEC FS-68V81S. The TV works extremely well and shows perfect video etc.
    I don't want to dump it because the picture quality is excellant. However intermittently it will not turn on.
    The remote has no effect. (remote is ok) I can only get life out of it by turning the main switch off and then on. The power led on the TV is red at this point. Using the remote to switch on causes the led to flash green about 10times and then it reverts to red. No picture. The remote now has no effect. Won't work.
    Later on it all works perfectly and may not fail for days or weeks. This happens anytime, day temperature can be hot or cold. Any clues out there
  2. JayCee
    JayCee
    Jan 20, 2004
    23,770
    Lanarkshire
    +2,572
    This is a UK/Europe based forum and we don't come across the same models here as you do down under...in saying that it's possible that the set is
    manufactured by another company and rebadged...check the rear label and see if "AK" or "PT" something is printed on it under the model no.
