NEC DVD Writer and External USB Enclosure
Discussion in 'Desktop & Laptop Computers Forum' started by mjn, Oct 24, 2004.
  1. mjn
    mjn
    May 24, 2001
    21,408
    Herts, England
    +8,966
    I've got a NEC 2510A DVD Writer, and i'm using it in a Mitec ME-360 external USB 2.0 enclosure (Oxford Semi OXFW911 Chipset).
    But i'm getting serious/strange problems, when writing DVD's.
    If i attempt to burn a DVD-Video, the burn process is successful until around 50% of the data has been written, then Nero shuts down and i get a fatal exception error. But sometimes, the burn process is successful.
    For example, i'll get problems when burning Battlestar Galactica Mini series, either part 1 or 2. But Stargate Series 8 is fine :confused: :confused:
    I'm using the same software, NeroVision, to remove the ads and burn to DVD.
    If i attempt to burn a DVD-Data......all i get is SCSI reset errors, before even the lead-in has been written to the disc.
    I think i've covered all angles, but i can't find a resolution.
    Just to rule out the DVD-Writer itself being faulty, i plugged it into my IDE port and i have no problems whatsoever.
    My motherboard is an Asus A7N8XE rev 2 Deluxe.
    Any help welcomed!!!
  2. HMHB
    HMHB
    Nov 11, 2001
    26,443
    Nottinghamshire
    +5,067
    Found this thread which seems to cover the same problem you are having
  3. mjn
    mjn
    May 24, 2001
    21,408
    Herts, England
    +8,966
    thanks John, i'm having a read of this now, and it seems i'm not alone!
