Nec Dlp Lt100
Discussion in 'Projectors, Screens & Video Processors' started by MajikNWA, Jun 13, 2002.
  1. MajikNWA
    MajikNWA
    Okay - took ther plunge and just grabbed one of these off ebay with a slight dark line on the picture. It was pretty cheap at 400 quid I think.
    Anyone used or got any opinions on these?
    Any idea how I could clean up the dark line on it without splashing out too much???
    Cheers,
    Majik
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,458
    Norwich
    +948
    do a search on avs forums
    there is absolutely s**t loads about it.
    its the the model before the lt150 and was modded to death.
    the contrast ratio is up there with the best that are still about today.
    you may want to search for the firmware fix if you get tearing on pal material.
    if you feel like opening up there are loads HOW TO's on AVS too.
    just about everyone did the colour wheel mod.
    as far as the line , i am not sure, can you take a picture??
    for £400 you got yourself a good deal, fed with a scaler it gives a stunning picture, look at maybe the pro-v that everyone is talking about it.
    but it is 1000 lumens, xga , and good contrast that can be betterd.
    result !!! :)
