NEC discrete codes
Discussion in 'Home Cinema Control & Remote Controls' started by Vis Man, Feb 12, 2002.
  1. Vis Man
    Vis Man
    Feb 22, 2001
    207
    UK
    +10
    Has anyone got discrete codes for the NEC 50" plasma (program for Pronto Pro). Ive tried remote central but no luck yet. The main buttons im after is on/off and rgb switching
    CHEERS
