NEC 9PG+ RGB sync on Green
Discussion in 'Projectors, Screens & Video Processors' started by stratman, Feb 25, 2002.
  1. stratman
    stratman
    I notice from reading the specifications for the NEC 9PG+ and 6010G switcher that both have sync on green as well as the usual RGBHV. Now does this mean that I could connect up my DVD player by making up a SCART to RGB cable (3 BNC's) and simply attach the composite video out to the green signal and earth pins and therefore do away with the requirement for a sync separator/amplifier. Also are RGB SCART sockets on TV's bidirectional, i.e. is there RGB output as well as input.
    Regards, Simon.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    RGB Scart is directional in that the sync is on composite so you need to use the composite OUT at the scart end.PIN19 earth on PIN17.
    I'll check later but off the top of my head if you put a 50ohm resistor from Pin19 over to G pin you'll get sync on green that way.
    Gordon
    Away for my lunch now. Don't do the resistor mod till I confirm.....
  3. stratman
    stratman
    Thanks for ther resistor info Gordon, I did a search of the forum and found a previous post where you say it is 50 Ohm. I'll get down to Maplins and give it a try. By the way what connection would you use to get the signal from terestrial TV into the projector?.
    Regards, Simon.
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
