NEC 42VP4 and Fujitsu P42VHA20
Discussion in 'Plasma TVs Forum' started by RossC, Jun 5, 2003.
  1. RossC
    RossC
    Feb 13, 2003
    144
    Does anyone have any experience/knowledge/views on this NEC display - dealer is offering it as an alternative to the noisy (buzzes) Toshiba 42WP27 that I have (swapped out, and second WP27 is slightly quieter, but will it get worse?).
    Understand that the Fujitsu is based on the samel Panasonic panel as the Tosh, so will it also buzz?
    Apprecaite your thoughts/experience. Thanks
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There's a VHA20 2m from my left ear, I can't hear it. It's been there 3 weeks, on a lot of the time so if it was going to it would have, if you see what I mean. The scart video board ias plain nasty though, RGB is worse than composite!! Using a JS VGA box, it's pretty good.
  3. johndonovan
    johndonovan
    MAW
    This screen looks interesting to me - planning to view during the next 2 weeks - would you recommend it from a PQ point of view and are you using the component inputs? If so, whats the quality like with these as opposed to SCARTs, which I don't need?
    many thanks
