NEC 42 XR3 - what's the downside?
Discussion in 'Plasma TVs' started by Sulis, Jan 4, 2005.
  1. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    So far I haven't heard a bad thing about this monitor. Given that it has at least the possibility of doing 720@50Hz (apparently), has every connection you could imagine, great reviews from the 2 people who appear to have actually seen one – what's the downside?
    The Pioneers are too big for the space I have available, the Pannies are horribly compromised by the HD thang... what choice do I have?
  2. UglyMoose
    UglyMoose
    Dec 15, 2004
    28
    Basildon
  3. Loada
    Loada
    Mar 4, 2003
    585
    Guisborough, North Yorkshire
    +48
    I too and looking seriously at this screen and am also waiting for a bit more feedback (thanks MAW btw). I think I read that one (minor) potential niggle is that the display will not support its native resolution @ 50hz via DVI (putting a spanner in the works for PAL pixel-mapping via a scaler?). MAW or one of the other resident experts can probably confirm this.
    I'd be interested to see what can be achieved via the VGA socket tho. Maybe the 50hz thing can be worked around using 100hz or something...
  4. 406lx
    406lx
    Nov 22, 2004
    895
    28
    Nottingham
    +27
  5. Andyuk911
    Andyuk911
    Sep 11, 2004
    413
    +9
  6. peezee
    peezee
    I find the 1024x768 resolution to be somewhat a "bastard" one.
    Let me explain: it doesn't correspond to any TV resolution, neither SD (720x576 for PAL, 720x480 for NTSC) nor HDTV (1280x720 or 1920x1080). In addition it doesn't even have square pixels which is good for PC application (via DVI as a matter of fact).
    At least the 852x480 SD panels have square pixels (and native NTSC definition btw).
    At least the 1366x768 HD panels have square pixels
    At least the 1024x720 panels have 720p HDTV vertical resolution
    But 1024x768...? :confused:
  7. grahamtriggs
    grahamtriggs
    Nov 19, 2002
    779
    28
    +33
    Depends on the PC application. Clearly the resolution and aspect ratio are out according to usual practise, but that doesn't necessarily matter, if the software takes account of the aspect ratio, or for that matter 'simple' text displays - such as timetables, etc.
    A 1024x768 resolution has the advantage that it is supported by all video cards that are currently on the market, and without the addition of extra software.
  8. peezee
    peezee
    graham, you understand exactly what I mean. :rolleyes:
    Whatever the source, PC or DVD or STB or... some vertical and horizontal scaling MUST be done by the screen (unless you have an external scaler, which does... the scaling anyway :rolleyes: ), meaning additional processing for video and softness for most PC applications (blurry text et all...). Which many other screens do avoid, at least partially.
    That's all, nothing too terrible, just a fact, these 1024x768 plasma screens have originally been designed for applications other than 16:9 Home Cinema, and it shows...
    except that circles appear oval and squares look rectangular then... :rolleyes:
  9. Likvid
    Likvid
    Dec 31, 2004
    489
    +9
    There are no plasmas today that complies to the HDTV standards of 1280x720 or 1920x1080, they are also compromises and you are the only one who can decide if it's worth it or not.
    There are always the excellent DLP TVs with native 1280x720 and HDMI inputs ready for Sky HD and such services when they begin.
    I am sure the plasma manufacturers will eventually release native 1280x720 or 1920x1080 panels once, either you live with the drawbacks plasmas have today or you go the fuill mounty and buy a DLP based TV which in my opinion have superior black levels and depth of the picture.
  10. Andyuk911
    Andyuk911
    Sep 11, 2004
    413
    +9
