NEC 3500 makes PC Crash
Discussion in 'Desktop & Laptop Computers Forum' started by chilpillphil3, Dec 24, 2004.
  1. chilpillphil3
    chilpillphil3
    Ive burnt 3 cd's DVD-r using my NEC 3500.
    Everytime it has made my pc crash after the burn is complete or near the.
    Does anyone have any ideas to stop this.
    OS: Windows XP.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Do you mean the PC crashes or just the burning software? What burning package are you using? Have you checked the event logs, they rarely pinpoint the problem but can indicate the general nature of it.
  3. chilpillphil3
    chilpillphil3
    Its Nero 6.
    I leave it,
    Come back, the screen is off, it wont wake up from keyboard strokes, and the lights are on.
    Im thinking it *might* be to do with the energy saver, so ill try switching it off.
  4. chilpillphil3
    chilpillphil3
    It's done it again, After about 30 mins.
    Im stuck for ideas.
    I put my CPU back to stock speeds, cannot see it helping much though :(
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    You disabled powersaving and the screensaver, yes? So what was shown on-screen once the PC had locked-up? What was the last thing Nero displayed?
  6. chilpillphil3
    chilpillphil3
    not alot it just froze,.
    Yep Screen saver off ETC.
    Anyway, i put the proiity down from high to normal and its fine.
    Not sure of the technical explaination though.
