Nebula DigiTv - Analogue VHS to DVD ?
Discussion in 'Desktop & Laptop Computers Forum' started by munkeenuts, Feb 28, 2005.
  1. munkeenuts
    munkeenuts
    Jul 16, 2004
    20
    3
    Hi all,
    I have ordered one of these cards after reading all the reviews about it on here. One quick question: If i connect the aerial out from my VHS to the input connector on the Nebula, will I be able to record my old videos to DVD format.
    Anyone tried it? If so what were the results
    Cheers in advance
  2. mephistopheles
    mephistopheles
    UHF connection woulkd work but better to connect the two via composite video. If your VCR doesn't have a separate composite out, you can use a SCART -> Composite/S-Video adapter (available from Maplin and most TV/Hi-Fi type stores.
  3. Gerbil
    Gerbil
    May 20, 2002
    270
    Newbury
    +26
    It might work, but not in the way you suggest I'm afraid. The aerial input on the Nebula is purely for it to decode the Freeview channels and pass-thru of the normal UHF signal to your Video/TV.
    The only other connector on the Nebula is a composite input for which you'll need the SCART to Composite/LR Audio as stated above. Be warned there's also no audio input on the Nebula. It relies on the existing audio input socket on your soundcard/motherboard. Most Scart to composite leads have phono plugs for the audio so you'll need an adaptor with 2xPhono sockets to 3.5mm plug to get sound in as well.
