Nebula Digital Tv card on a network?????
Discussion in 'Desktop & Laptop Computers Forum' started by dealmaker, Jan 6, 2005.
  1. dealmaker
    dealmaker
    Feb 21, 2001
    741
    nearly in Scotland!
    Guys,
    I have a Nebula digital TV PCI card on my main PC.
    I'm now setting up a wired home network with a couple of other PC's.
    Is there any way for the other PC's to share the card and view TV programmes?...or, as I suspect, do I need to buy a card for each PC (WHICH i'M NOT GOING TO DO!).
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Yes .
    No you don't need additional nebulas for each machine.
    And I've never used it myself.
  3. dealmaker
    dealmaker
    Feb 21, 2001
    741
    nearly in Scotland!
    Mr D,
    Thanks - so how do I go about sharing it out??
    Do I need to load drivers on other PC's?
    JUst have not got my head around how this would work??
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    You install the digiTV software on your "client" machines and then you serve to them using your "host" machine with the nebula card.
    Unlikely to work reliably over wireless but like I say I have yet to use it this way.
  5. dealmaker
    dealmaker
    Feb 21, 2001
    741
    nearly in Scotland!
    Mr D,
    OK thanks - actually I'm going to use a hard wired connection, via a router, - so have you actually done this on your system?
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I haven't done this myself but others have . I assume all you have to do is sort out your network and any associated firewall issues. The manual for the nebula covers this.
  7. Epithet
    Epithet
    Dealmaker
    I have played with networking the Nebula.
    On the PC with the card installed "right click" within the window and select "settings". Choose the "Network" tab and set the pc the DigiTV Server. It is worth examining the options whilst your at it.
    Install the DigiTV software on the client PC - no need for the drivers. Run the software and it will alert you that it found no hardware. Ignore this - you can disable this alert in one of the setting options. Right click on the window select "Settings" then "Network" and set the PC to DigiTV client. Assuming the server PC is running, the client should locate it. I had to play around with the multicast setting to get the client to work propoerly. Further help at:
    http://www.nebula-electronics.com/support/help.htm
    There are certain limitations to what the client PC can watch. These limitations may be overcome by a planned hardware development by Nebula. Speak to Nebula for more information.
    Regards
    Tony
  8. Digger
    Digger
    Dec 31, 2003
    4,385
    World Wide Supermarket
    +205
    ....apologies for interrupting but i am having some trouble getting my Digitv client to see the server, and vice-versa (obviously). Everything is setup as i believe it should be. client is a wireless laptop, and all running through a Netgear wireless router with port forwarding enabled. File-sharing / ping etc works just fine. I tried multicasting option too. I have turned off XP firewall too.
    I cannot even specify the Digitv Server's IP address as the option is grayed out as the software looks for it automatically. If i could just get in there and change it I am sure it would work.
    Any ideas? (edit: I have just started a separate thread for this)
    cheers
    Dave
