Nearly completed my room - Advice needed
mikeinmk
I have been reading this forum for a while and have been physically and mentally spending a lot of cash after seeing some of the setups here to kit out my place.
I hope to have some pics up very soon once I have finished my living room.
I am looking to purchase a reciever with 2 HDMI outputs to replace my current all in one system and was wondering if anyone had any recommendations from experience.
Mike
Bartholin-01
I'dd Like to help you out, i need some info first though.
Whats your budget?
Do you need speakers too? or do you already have the once you intend to use? - in that case:
What speakers do you have?
Size of living room? - Maby a picture?
What else do you expect from your receiver? Design, power or both?
Good luck on your project man ;)
Looking forward to the result :D
mikeinmk
Thanks.
Yep will post to AV Amplifiers and Receivers Forum at AVForums.com also, so many forums, missed that one.
Thanks, Iccz, Bartholin-01, SteveCritten.
In anser to Bartholin-01.
Whats your budget?
Around £1000 for the receiver
Will need speakers, I have speakers for my all in one that I am use for a while but I will buy speakers for the new reciever. Not sure the ohms etc of the current speakers but they will have to go.
Speakers are out of a seperate budget to the receiver, spend no more than £1000 on speakers depending on the reciever spec 5.1 7.1 etc.
Room is approx 4 metres by 5 metres long with screen on the 4 metre wall.
I would like an nice looking box but to be honest it will most likely endup in a cupboard never seen. Would like hdmi 1.4 for 3D. No less than 4 hdmi in and 2 out, power around 85w or more, 5.1, or 7.1 would be great, streaming not needed as I use PS3 for this.
Fitted remote control curtain rail today, neary done. ack to escape from Alcatraz on the big screen :eek:)
Pics next week
Cheers,
Mike
