horribleman
Established Member
- Joined
- Jan 28, 2005
- Messages
- 527
- Reaction score
- 47
- Points
- 128
Hi there
I just bought a navman s70 to replace my garmin i3 which could never find the satellites.
The navman works perfectly, and I've worked out its idiosyncracies (i.e. change the route preference based on whether you are crossing london or not ) however I cannot get it to work with my mobile as a hands free kit.
I have a SE W890i, and the devices can see each other. I can even see incoming and make outgoing calls with the navman, but the audio is not routed through the navman.
Anyone know what I'm doing wrong?
Also, is it possible to load tom tom software onto the navman?
And are there any good mods to look for?
Cheers!
Cheers!
