Nautilus speakers for A32/CD33/DV79
Discussion in 'Arcam Owners' Forum' started by gregeas, Nov 1, 2004.
Tags:
  1. gregeas
    gregeas
    May 7, 2004
    175
    NYC USA
    +6
    Well, it looks like I will probably pull the trigger on a pair of B&W Nautilus 804s.
    I'm wondering if anyone has matched these speakers with the Arcam A32 amp. Does the Arcam have power to drive these speakers? Does the bass show up? (I've read that in some systems, the speakers are bass-shy.)
    The 804s are quite revealing, so I believe my Arcam sources (CD33 + DV79) will do fine in the system.
    Any thoughts or comments?
  2. Hifi addict
    Hifi addict
    The A32 will do absolutely fine ! I used that amp to drive the 804 and 803 and it worked fine on both speakers. It has plenty of power and will sound very good.
    The A32 will keep the bass under control etc etc, it will be a very good choise.
  3. Harbornebloke
    Harbornebloke
    Apr 5, 2004
    138
    Birmingham
    +11
    Hi gregeas
    I have the "baby" version of your system, A85, CD192 and B&W CDM 1NT's. I thought that the set up sounded great untill I added a P85. The change blew me away. IMHO it's well worth getting a demo with the P35. I think that you'll love it!
    Phil
  4. warrj
    warrj
    They will probably sound OK. But, to be frank, the A32 really won't do a pair of 804s anything like the justice they deserve. You really need something like a Krell-class amp to hear how the 804s are meant to sound.
    Regards,
    Jules.
  5. gregeas
    gregeas
    May 7, 2004
    175
    NYC USA
    +6
    The audition I heard at the dealer was with a huge MacIntosh amp and source, and the music was stunning. The dealer carries Arcam but didn't have the A32 in stock to demo. So I'm kind of going in blind (deaf?) here. In my research I did notice many people using very high-end amps with these speakers. So there's probably another upgrade on the horizon if I go for the 804s. Thanks for the thoughts.
  6. JH1
    JH1
    If you decide to keep you Arcam amp, give the B&W 700 series a try. Not sure if the nautilus 804 is a stand mount or floor stander but if you are considering floorstanders I have heard the 704's and 703's and they both produce great results with the right equipment. I was convinced and bought the 704's, mainly 'cos I couldn't afford the 703's and also they are a little bit bigger. :thumbsup:
  7. mattross
    mattross
    Oct 23, 2004
    265
    +7
    For a few months before upgraditis was completed I drove my Nautilus 804s with my old Arcam Delta 290 integrated amp and they still sounded stunning to me. Bass was awesome, these speakers rock!
  8. gregeas
    gregeas
    May 7, 2004
    175
    NYC USA
    +6
    I ended up buying the 804s and am very pleased. I've ordered the P35 amp to go with the A32. This combo should drive the 804s with no problems (I hope, because the upgrading must stop!).
  9. Hifi addict
    Hifi addict
    congratulations on your purchases ! enjoy them
